It is currently Thu Jul 30, 2026 8:45 am
Post Posted: Wed Dec 29, 2010 10:11 pm
At the moment i am in the middle of a engine build for a friend
I was wondering if anybody had done this before?
If so do you have any tips or problems when it came to valve timing/timing belt setup?
thanks aleks
Post Posted: Wed Dec 29, 2010 10:40 pm
Yeah many have done it before though I am not one of them so can't help you with detail. I do remember something about a porsche timing belt though... A good one is Dave loftus's race starlet.
Can I ask why you guys went this way though, what is it for? It is only a stroke increase on a 4a and so while you will gain a bit of capacity there is a loss of 'revyness'. Also on a budget 4agze would have a lot more more power and with forged pistons as standard you can go a turbo upgrade and get a LOT out of it without even having to open up the engine.
Post Posted: Wed Dec 29, 2010 10:55 pm
You got me interested so I googled it. They use a Porsche 924 or 44 timing belt. Has to be 117 tooth. Here are some interesting links.
http://www.tunemytoyota.com/forum/showthread.php?t=1144
http://www.6gc.net/forums/index.php?showtopic=68083
http://www.aeu86.org/index/engine-4age- ... post=60902
Post Posted: Thu Dec 30, 2010 1:52 am
u also loose compresion. so makes it perfect for boost. looked in2 it years ago.
Post Posted: Thu Dec 30, 2010 3:04 am
True with a built engine (though it is still higher then a 4agze). With boost and 7a stock internals I think you would see problems before you got anywhere near 4a-gte power (for the same money). Just depends what you are using it for?
Skelaaleks mentioned build so I am guessing you are going forged internals? or at leas gze pistons?
Post Posted: Thu Dec 30, 2010 3:14 am
Wouldnt it be better off asking on toymods or rolla club? My brother has always wanter a 7age in his 00 bubble butt rolla...
Post Posted: Thu Dec 30, 2010 5:05 am
its going into a ke76 corolla.
the car is a weekender/track/drift car.
we had forged rods but then my mate sold them.
he is going to get another set.
i know that the bolts in the rods need to be replaced with studs(my mate rekons that the bolts strip the threads in the rods if reved hard
mods to the motor will be
7ae block
4age head
4age pistons
7ae rods
everything balanced
port mach everything
adjustable cam pulleys(needed for the different head)
quad throttle bodies
aftermarket ecu
for the moment it will be n/a
but mostlikely be turbo charged after about 1 year or running.
Post Posted: Thu Dec 30, 2010 5:18 am
thanks for the links
i already knew about the timing belt
Users browsing this forum: Google [Bot] and 90 guests
