It is currently Sat Oct 24, 2026 1:52 am
Vehicle: 91 Sierra
Post Posted: Fri Dec 24, 2010 10:30 pm
the short version - it appears i have to swap the cam in a F10a
The engine is in the car, does anyone have a ' how to ' bit of literature on the procedure ?
Getting it out i predict will be possible, putting it back in properly may be the issue :?
Vehicle: LJ20 LJ50
Post Posted: Fri Dec 24, 2010 10:43 pm
http://www.suzukiinfo.com/lj/lj80fsm.zip
19.5 mb full factory service manual download
Camels have nice toes
Post Posted: Fri Dec 24, 2010 10:55 pm
generally caused by prolonged oil change intervals in the F10a, wears down the cam lobes
Vehicle: 91 Sierra
Post Posted: Fri Dec 24, 2010 11:17 pm
cheers for that, the pictures are a biy fuzzy but hey the price was right. had a quick look and it appears it may be a bit much for me to attempt
Vehicle: 91 Sierra
Post Posted: Wed Jan 05, 2011 5:43 am
Post Posted: Wed Jan 05, 2011 7:20 am
Cam has to slide out the front. Rocker shafts both need to come out first I think.. This may not be easy with motor in car.
Post Posted: Wed Jan 05, 2011 7:37 am
the gear that drives the dizzy can be changed over without removing the camshaft
Vehicle: 91 Sierra
Post Posted: Wed Jan 05, 2011 8:29 am
Post Posted: Wed Jan 05, 2011 7:42 pm
no i meant the gear on the camshaft.....
Post Posted: Wed Jan 05, 2011 8:27 pm
lauby wrote:
Oil leak - A drip every 2 seconds or so out of one of two 3mm dia. holes on the dizzy housing. It then ran down the back of engine onto the exhaust, not good really. Speculation by sparky was if hole was plugged oil would travel further up and into the distributer cap. Best guess because it spins backwards it's basically sucking instead of creating a positive pressure keeping the oil at bay.
Doesn't matter which way the dizzy spins, it does not build any pressure - there's a seal in there that's leaking.
Vehicle: 91 Sierra
Post Posted: Wed Jan 05, 2011 9:01 pm
hmmm, i now have differing opinions, i was told this can't be done. Will pull the cam out of the dead Maruti engine and have a closer look.
fordem wrote:
Doesn't matter which way the dizzy spins, it does not build any pressure - there's a seal in there that's leaking....
Might have to try a different sparky, i asked him this. it didn't leak before and as far as i know the only thing that was touched was the gear / lead plug on the end. It doesn't leak from the shaft mating to the housing, it's a factory hole a bit further up...
Post Posted: Wed Jan 05, 2011 9:31 pm
The gear on the cam is NOT removable.....
If it were my job, I'd remove the head.
Swap the cams and relap all valves and refit head....
Vehicle: 91 Sierra
Post Posted: Sat Jan 08, 2011 3:40 am
Thanks Jas, tow'd car, mentioned this to the mechanic and left it with him, lets see what happen$ .....
Post Posted: Sun Jan 09, 2011 12:45 am
ohh really ?
cause every 1 litre ive worked on it has been..
Vehicle: MG410
Post Posted: Sun Nov 06, 2011 1:05 pm
Hi guys,
Sorry to bump an old topic.
I have a f10a carry with a blown bottom end.
I have bought and started prepping a maruti f10a.
Few questions
1. is the cam profile different between the carry/sierra/maruti f10a's?
2. is a puller sufficient to remove the dizzy timing gear off the camshaft or will i need a hydraulic press? would i be better off swapping in the carry cam?
3. is there anything else i need to consider? am i missing something?
Post Posted: Mon Nov 07, 2011 1:17 am
losfer wrote:
ohh really ?
F10A and F8A have replaceable cam gears that are replaced by heating and pressing on. G series engines (G13A, G16A/B) have cam gear integral to the camshaft and cannot be replaced.
Maruti MAY have gone to a one piece manufactured cam shaft, but Suzuki ones are certainly replaceable.
Users browsing this forum: No registered users and 137 guests
