It is currently Wed Oct 21, 2026 7:27 am
Post Posted: Wed Jan 19, 2011 9:02 am
I built a new rear bumper with LEDs, and yes it does flash too fast, I hoped I,d get away with because of the old lights on the front but no.
Supercheap want $34. for a 3 pin, but only $18. for a two pin can I adept a 2 pin, ,cause I paid $28 for a ordinary flasher unit 1 monthago
tar
Post Posted: Wed Jan 19, 2011 9:07 am
I'm running a 2 pIn type one and works fine
Post Posted: Wed Jan 19, 2011 9:14 am
keep the flasher.
add a resistor inline with your LED's.
dunno what value you need, but since they're a few cents each, buy a pair of each value you can get at dick smiths, and wire them in until you reach a flash your happy with.
Post Posted: Wed Jan 19, 2011 9:26 am
I would suggest that given the power these inline resistors are gonna need to handle some $0.05 1/4W resistors aren't going to be up to the job...
Also, the resistor would need to be in parallel with the LEDs, not inline...
I want my old sig back :(
Post Posted: Wed Jan 19, 2011 3:39 pm
A cheap 2 pin thermal flasher unit worked fine in mine when i had LED rear lights. Had to go a proper LED flasher now i run LED's all round, Narva 68249 2 pin, $14.00 from electrical wholesaler.
Post Posted: Thu Feb 17, 2011 5:32 am
I bough a 2pin flasher unit{non-load bearing], but didn't work..-another $30.....Got NARVA LOAD RESISTOR 2 OFF.
Yeah works perfectly.
Warning: Load resistor must be mounted to metal surface.
Operating temperatures can reach 170C damaging plastics,carpets and painted mental surfaces.
P/No.90034BL.
Only 2 auto-electrical wholesales in Cairns, and they reckon there is no straight swap for Suzuki flashers.....you need to rig up little leads.
$30. for the pair from
ashdown- Lsomethink......... bye
Post Posted: Thu Feb 17, 2011 7:07 am
P/No.90034BL.
I can vouch for that, we tested it at work, cause the boss didn't believe it..
Post Posted: Thu Feb 17, 2011 9:08 am
i had the same problem my self you can get 3 pin led flasher cans off ebay cost around $25 posted and now my indicators are back to normal
Post Posted: Thu Feb 17, 2011 11:53 pm
i tried 3 different cans/flashers, still didnt work.. Always flashed fast..
With all wiring correctly re-routed.
Will have to try more with my new zook.
Post Posted: Fri Feb 18, 2011 6:35 pm
the one ive got is spcific to stop hyper flash when using led lights i think the body of the unit is a mm or 2 bigger but it still pushes in
Users browsing this forum: No registered users and 153 guests
