It is currently Tue Nov 03, 2026 6:32 pm
Post Posted: Thu Jan 20, 2011 6:17 am
hey is the chasie built around the gearbox
it just woun't come out ...........the fan is aagainst the radiator, I have heard of doing it by rotating the box, but naa
I know I shouldn't start another thread but it was nothing like thed preceding changing clutch thread
I hav't even mentioned the wires that hang persistantly to the top of the fuck'n thing
It's the nephew's car and he's with me occassionaly' but not when needed
All help welcomed
Thanking you in anticipation
Vehicle: Nissan
Post Posted: Thu Jan 20, 2011 6:32 am
pull the gear box back as far as possible and let the front of the box down it may hit the pressure plate but you should be able to get it past :) trty this let me know how you go :wink:
Pearce-toff Racing
Post Posted: Thu Jan 20, 2011 7:13 am
kindly to please read the thread on changing clutch, gearbox just does not
come out
tar
Post Posted: Thu Jan 20, 2011 7:16 am
When someone has an answer they will give it too you... There is no need to keep posting :roll:
I want my old sig back :(
Post Posted: Thu Jan 20, 2011 7:17 am
would help if you keep it all in one thread... :wink:
http://auszookers.com/index.php?name=Fo ... ic&t=18390
have you tried what alex suggested?
Vehicle: 2018 DMAX
Post Posted: Thu Jan 20, 2011 7:20 am
what is it in?
Post Posted: Thu Jan 20, 2011 7:22 am
did that, even jacked the back of the engine up......1 or2mm in it
Post Posted: Thu Jan 20, 2011 7:26 am
sorry...............it's a '93 swb serria
Vehicle: 2018 DMAX
Post Posted: Thu Jan 20, 2011 7:29 am
In mine i need to remove the front driveshaft because of my exhuast location. then turn and twist it to the left... Just scrapes the pressure plate.
And if you putting a new clutch in, it wont matter if you damage the pressure plate...
Post Posted: Thu Jan 20, 2011 7:45 am
Try jacking the front up...
Post Posted: Thu Jan 20, 2011 8:09 am
ok i'll jack the front of the engine up in the morning.....took the front drive sharft off....guess I'll jack front up after I drop front of box...broke exhaust near transfer case, and pulls aside
Post Posted: Thu Jan 20, 2011 8:17 am
They DO fit out, it a lil bit of a pain, but with luck you shouldn't havae to do it again for a while..
Have you removed the G/box mount & bracket off the g/box?? Make's a big difference..
Users browsing this forum: No registered users and 62 guests
