It is currently Sat Oct 24, 2026 6:14 am
Board index » ausZOOkers » Website Help & FAQs
Post new topic Reply to topic  [ 262 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 9  Next
Vehicle: 91 WT 1.6EFI
Post Posted: Sat Sep 18, 2010 12:05 pm
I'll help out for sure
Vehicle: Suzuki
Post Posted: Tue Oct 12, 2010 8:38 am
I can help out with imagery... Just need some good mechanic hand models... *looks at stekky* :lol:
Post Posted: Tue Oct 12, 2010 9:13 am
Don't know why you mentioned me then.. :lol: :lol:
Would that make me a hand model?? 8O :P
Post Posted: Wed Oct 27, 2010 11:37 pm
Hope this is the right place for this - Is there already a thread on issues of Vitara gearboxes? After my clutch cable snapped it's pretty difficult to get 2nd or 4th, and all the gears are pretty loose. Any threads outlining what this could be?
The LWB From 1993. Poetry in motion :P
Post Posted: Thu Oct 28, 2010 12:17 am
clutch pedal isn't cracked? Joe had a similar problem.
Post Posted: Thu Oct 28, 2010 12:27 am
No but as soon as it gave way that was the first thing i checked, I remember seeing that a while ago... I've replaced the cable and it's all good but I'm guessing a pin or seal or locating thingy has let go, just hoping someone knows a common fault.
Vehicle: 96 coily Awesome sticker Rust
Post Posted: Wed Nov 03, 2010 12:50 pm
Vitara
I have issues
What are you looking at
Post Posted: Fri Nov 12, 2010 9:17 am
guys, i remember seeing a thread a while ago for a sierra body swap, i had a quick search but didn't come up with anything...any chance someone knows where it is??
Post Posted: Fri Nov 12, 2010 9:19 am
as in difference in body mounts NT/WT? got any more info?
Post Posted: Fri Nov 12, 2010 9:22 am
i remember seeing it too. i think it was the 2 mounts in the middle crossmember were the difference?
Think before you post to make AZ a better place :)
Post Posted: Fri Nov 12, 2010 9:27 am
this one?
http://auszookers.com/index.php?name=Fo ... ody+mounts
Post Posted: Fri Nov 12, 2010 10:17 am
nope, as in someone did a write up on actually doing it.
Post Posted: Wed Jan 12, 2011 2:26 pm
I can't for the life of me find the thread/post 93zook is looking for, anyone else got any ideas?
Why can't I sleep like a normal person?
Post Posted: Wed Jan 12, 2011 2:28 pm
Pretty sure NT/WT/Coily bodies are all interchangable... Could be wrong, but pretty sure...
I want my old sig back :(
Post Posted: Thu Jan 13, 2011 11:00 am
there was a thread with an lj body going on a later model chassis i think
Post Posted: Fri Feb 04, 2011 11:28 am
prob wasn't even this forum lol. its done now anyway :wink:
Post Posted: Mon Feb 07, 2011 4:05 am
anyone know how wide a 106 hilux diff is when it has IFS hubs?
buy my calc's it is 1473mm wms to wms. is this correct?
also is early model hilux front spring spacing the same as a 106 hilux?
Post Posted: Mon Feb 07, 2011 5:24 am
this info any good? :? 58" = 1473.2mm
http://www.outerlimits4x4.com/viewtopic ... IFS+spacer ?
"Most guys in the states use this or an 'outside the hub' wheel spacer on the front axle to make the WMS 58 inches - matching the width of a 86+ V6 truck G294 rear axle they've installed."
Post Posted: Mon Feb 07, 2011 6:10 am
cheers mate :D thats what i came up with so there is a good chance it is right.
i think i will use a marks ifs adapter just cos its aussie and i have used some of there stuff in the past.
fuck i hope i get approval to build the car :D
Post Posted: Mon Feb 07, 2011 6:15 am
me too, who ever thought you'd be building a Vitara up... aka shep's mobile hair salon. :wink: Armsup
NFI about the spring spacing on the LN 106 lux, might pay to post up on outers.
Post Posted: Mon Feb 07, 2011 6:53 am
anything would be better then a troopie for a family car which by the way
i find out on wed if i have scored another troopie for cheap, 2006 model this time :oops:
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Sat Feb 12, 2011 2:29 am
Links for good 4k conversion tech?
'88 Tin Top Sierra, '95 JX Vitara Estate
Go hard,
Post Posted: Sat Feb 12, 2011 2:37 am
Grimbo says :no:
Post Posted: Thu Feb 17, 2011 10:57 am
were any sierras available with just a lap seat belt in the front?
Post Posted: Fri Feb 18, 2011 5:32 am
Nope, n/t's & lt's had non re-tractable..
Post Posted: Fri Feb 18, 2011 6:05 am
cheers mate :helloo:
Post Posted: Fri Feb 18, 2011 6:10 am
:P
Post Posted: Tue Feb 22, 2011 11:23 am
time for a new avatar but i cant remember how to make the picture the right size. can someone make this the right size for me?
Post Posted: Tue Feb 22, 2011 11:29 am
Post Posted: Tue Feb 22, 2011 11:30 am
try that one shep, if it doesn't work i'll re do it at work tomorrow night.
