It is currently Mon Oct 19, 2026 10:11 pm
Post Posted: Mon Feb 07, 2011 5:49 pm
I Knowthere is a thread about this,but I can't find it.
Me car idles up when lights or heater fan are switched on.
I played with the thingy on the front of the carby, but to no avail, I screwed it in as far as the spring will allow, should I have screwed it the other way.I worried that the spring would not hold tension on the bolt, and it might fall out.
Thanking you in anticaption.
bye bye
Post Posted: Mon Feb 07, 2011 5:59 pm
When you turn you fan or lights on it's meant to idle up.
Post Posted: Mon Feb 07, 2011 8:02 pm
I had my lwb carby rebuilt and dynotuned, and it doesn't do it.
bye bye
Post Posted: Mon Feb 07, 2011 8:04 pm
Is it possible it's got something to do with the size alternator?
bye again
Post Posted: Mon Feb 07, 2011 9:03 pm
No it's meant to idle up. On the front of the carb there is a Solenoid(Idle up switch) that pushes in and adjusts the idle (I know someone here can explain better than me) Go start your car, get someone to turn your lights on and watch it.
http://auszookers.com/index.php?name=Fo ... le+working
Post Posted: Mon Feb 07, 2011 9:59 pm
it idles up to keep because it needs to, the lights and fan draw power and wile your on idle id wont give out enough juice so it idles up
Post Posted: Mon Feb 07, 2011 10:09 pm
That explains it perfectly. (Bruce does Tech again! 8O )There will also be a 2nd Idle Up Switch fitted with Aircon, which does the same thing when the compressor kicks in and the car is idling.
Read a bit more about the carb HERE. The Idle Up system is on Page 9.
Post Posted: Mon Feb 07, 2011 11:06 pm
bye bye
Nice who'd you get it done by? Not the place behind Anderson street?
Lil Foot!
Post Posted: Mon Feb 07, 2011 11:16 pm
ohhhhhhh gee it's not often I can talk about tech here :oops:
Thanks 303 :helloo:
Vehicle: I drive your mum
Post Posted: Tue Feb 08, 2011 4:27 am
The idle up is controled by a solenoid, that allows manifold vacuum to flow to a vacuum pot on the front of the carby. This vacuum pot acutates on a lever attached to the throttle shaft. Screwing the adjuster screw in will raise the idle up speed. From memory when the idle up is off the stopper doesn't touch the plate. Usually there is the adjustment screw, which has a lock nut on it to stop it vibrating loose when its not in use. You should have approx 1000~1100 idle up when electrical load is applied.
Layto....
Post Posted: Tue Feb 08, 2011 12:02 pm
yea i had it done off anderson st
Am I to expect some problems with the battery sometime, I rearly drive it at night, but have the lights on when it's raining.
It was done about a year ago (5,000 K), and all's sweet so far
bye bye
Users browsing this forum: No registered users and 218 guests
