It is currently Tue Oct 20, 2026 9:24 pm
Post Posted: Tue Feb 08, 2011 7:12 am
when i turn the key to start it, it makes a click noise then nothing as i hold it then after a few seconds of holding it on finally rolls over..
its a g16b btw
thanks
Post Posted: Tue Feb 08, 2011 7:17 am
check battery an all connections before you panic
Post Posted: Tue Feb 08, 2011 7:21 am
Yeah, it's totally F'd... I'll happily take it off your hands though. 8)
thank me later 8) :D
http://auszookers.com/index.php?name=Fo ... tarter+fix
Post Posted: Tue Feb 08, 2011 7:34 am
I applied the fix with the relay and it worked for 2 months and I just put a reco starter in this weekend.
Post Posted: Tue Feb 08, 2011 8:00 am
ahaha hopefully that works, its only just started doing it after a muddy trip, and it seems to be getting worse :/
ill give it a go and see if it improves
cheers :D
Post Posted: Tue Feb 08, 2011 8:44 am
cheers :D
Strip, clean, grease the bush's ( NOT BRUSH'S) re assemble & bench test before refit, you will have bad contact in the solenoid..
Users browsing this forum: Google [Bot], Google Adsense [Bot], Susiethezook and 225 guests
