It is currently Sun Nov 01, 2026 1:54 am
Post Posted: Thu Feb 10, 2011 8:05 am
http://www.suzistore.com.au/shopexd.asp?id=378
I was just wounder if anyone knows what the bottom gray pipe on the SJ80 fuel pump is? I am guessing it might be a vacum line which might advance the pump rate ???
Vehicle: SJ80
Post Posted: Thu Feb 10, 2011 8:09 am
It's a cam driven pump, so rate is directly proportional to rpm, and the line is an overflow in case the pump shits itself internally.
Post Posted: Thu Feb 10, 2011 8:17 am
sweet. so what should it be hooked up to? someone has plumed mine up to a vacuum line on the intake manifold
Vehicle: SJ80
Post Posted: Thu Feb 10, 2011 8:21 am
Mine was never hooked up to anything :? I'll try and find you a photo from when I did the engine swap in mine.
Edit: This is the only photo I could find. I definitely didn't disconnect a vacuum line from it. I guess it's possible that it may have had one which was removed prior to my owning it - maybe to return spilt fuel through the carbon cannister. Do any other coily owners have it on theirs?
Post Posted: Thu Feb 10, 2011 8:41 am
yeah i am trying to suss those hoses on mine.
my fuel pump overflow is plum up to the carbon canister pipe (which someone has cut out for a battery tray). the solid pipe to carbon canister has then been joined back up to a pipe that runs back to a vacuum line on the intake manifold.
while the solid fuel tank breather line has been bolted up ????
Post Posted: Thu Feb 10, 2011 9:10 am
if you have a vacuum hose connected to it , thats most likely your problem , it will stop the pump from pumping fuel and make it jerk.
the pipe is just a telltale for oil to escape when the pump seals are screwed
Post Posted: Thu Feb 10, 2011 9:30 am
hmm very interesting. i was chancing any vacuum leaks as i had a irregular idle some times (1000 rpm dropping down to 200rpm) and i noticed that the intake and exit pipes where the charcoal filter was were just connected together with a rubber hose that was too big. I thought this was my vacuum leak so i sealed it up with two hose clamps.
while i was at it also replace my plastic fuel filter with a finer fuel injected fuel filter to try and stop the idler jet getting clogged.
Then when i took it for a test run it was occasionally leaning and stilling. I just assumed it was the finer fuel filter restricting the flow of fuel .... could have been the vacuum on the fuel pump making the diaphragm jerking
Post Posted: Thu Feb 10, 2011 9:51 am
i can assure you that vacuum there will cause a fuel pressure drop problem
Vehicle: SJ80
Post Posted: Thu Feb 10, 2011 5:41 pm
Also sort this out. Fuel can't get out properly if air can't get in to replace it.
Sounds like the whole set up has been bastardised.
Post Posted: Sat Feb 12, 2011 5:38 am
yeah definatly mucked around with. Should i plum up the fuel tank breather pipe to the airbox or a vacum line off the intake manifold?
I was think airbox with a one-way value so it only allows air in and not fuel / air out.
Post Posted: Mon Feb 21, 2011 12:10 am
Does anyone know where i should pump my fuel tank vent pipe to if i do not have a charcoal canister? carbie vacum line, air box or block it off all together?
Post Posted: Mon Feb 21, 2011 7:01 am
No, no & no....
get a cheap fuel filter & put it higher than the tank & nowhere near spark's or heat...
Or, get a charcoal canister, safer.... :D
Users browsing this forum: No registered users and 475 guests
