It is currently Mon Oct 12, 2026 10:07 pm
Post Posted: Sun Dec 05, 2010 5:45 am
So they are meant to be the ducks nuts, longer travel, nice ride, good stuff.
Ive had em in since the day I got my vit, replaced with a new set maybe 2 years ago cause the others went a bit shit and needed some movement to get the air out of the piston.
Today I went to do some stuff to teh front of the vit and checked the struts cause it felt a bit soft rolling out my driveway
Now my vit doesnt go offroad other than some beach when I get time, I have enough modded dont care if you beat it up a bit 4wd's at my disposal so it doenst need to, hell it only ever really runs up and down a highway every day
So why after 2 years and maybe 40000km ARE THESE FUCKING EXPENSIVE YOU BEAUT BEST YOU CAN GET STRUTS BOTH FUCKED!!!!!! I know these things dont last but thats just plain old shit, I believe they go on with some warranty bullshit but we all know ARB warranty is worth for shit so I guess I'm out a few dollars.
Funny that the 100000km old Rancho 9000's on the rear are still fine, wonder if they do a nice front strut :roll:
So, how do I get warranty, or do I weld them to the bollards out the front the local shop and spend em on something else?
Post Posted: Sun Dec 05, 2010 6:00 am
Yes having helped Royce today play with his heap, they are rather fucked.
Get your receipt docket :wink: and put in a claim.
They would onlt be 2 years old at that Royce. Cause we fitted them when we put them great spacers in :wink:
Post Posted: Sun Dec 05, 2010 6:02 am
They will blame the spacer's, I would.. :P
Post Posted: Sun Dec 05, 2010 6:04 am
warranty void.
:finger: :wink:
Post Posted: Sun Dec 05, 2010 6:05 am
it'd be handy if you knew someone that works for ARB that might be able to 'ignore' the spacers. :wink:
Post Posted: Sun Dec 05, 2010 6:07 am
if I took em in out of the car how would they know :wink:
they arent leaking either so its not from topping out
Post Posted: Sun Dec 05, 2010 6:09 am
Yep True. Just lots of air in there till you push them up and down a few times then they seem ok?
How as the ride home Royce?
Post Posted: Sun Dec 05, 2010 6:13 am
funny though its only rebound not compression so I wonder if its a valving thing
yeah the new rears are pretty good
Post Posted: Sun Dec 05, 2010 7:45 pm
DOA sell "extreme" long travel struts that don't last long, should give them a go... 8O
Vehicle: Suzuki Grand Vitara
Post Posted: Wed Dec 08, 2010 8:20 am
That is pretty crap lifespan, the Calmini shocks in my Vit have done 100 000klm and they are surpose to be not that good quality.
Post Posted: Wed Dec 08, 2010 8:26 am
You haven't been doing this have you Royce?
I want my old sig back :(
Vehicle: 2004 SQ625 GV
Post Posted: Fri Feb 11, 2011 12:33 am
My drivers side OME strut has failed now.
I did get them second hand but was told they did not spend long on the vehicle and once my car they would have been lucky to have done 5000km.
I am iffy about getting another set if they fail that early for the price they are.
Post Posted: Fri Feb 11, 2011 12:37 am
I have been thinking about them and I reckon they must jsut leak the oil out so you get a pocket of air that needs to get pumped back to the top
I found some nice Koni coil overs the other day that are designed to have strut ears welded onto them so they could be made to fit, lots of adjustment and 10" travel too :)
Post Posted: Fri Feb 11, 2011 12:51 am
The Koni's would be cool.
The rod has side movement in the strut body. I haven't noticed any oil leaking yet but I have noticed a a lack of rebound control.
They are a nice riding shock but once bitten.........
Post Posted: Fri Feb 11, 2011 2:58 am
No troubles with my OME struts, very pleased,
original owner used it hard of road, so do I.
I think they are supposed to have little resistance to up travel,
then stop the recoil on the down stroke.
Hence nice soft ride.
I also think they are supposed to be "reactive" to speed, thus stiffen up at higher speeds.
But I could just be talkin out the wrong end?
Post Posted: Fri Feb 11, 2011 3:00 am
The rebound in teh shock is what stops the bouncing, it arrests the built up energy in the spring from it compressing, otherwise the suspension would 'jack up'
Post Posted: Fri Feb 11, 2011 3:09 am
I misread your post.
Thought you meant it was working ok on rebound.
Not faulty on rebound.
Thats definately not a good thing.
Users browsing this forum: No registered users and 299 guests
