It is currently Wed Oct 28, 2026 6:47 pm
Post new topic Reply to topic  [ 130 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Vehicle: 89 Vitara jlx SWB
Post Posted: Mon Feb 14, 2011 7:20 am
Trust me, if I didn't have extended brake lines I would'nt be able to get the coils in... haha
Looks sweet!
How hard was the guard chop? Did they rub with the 80mm TD kit?
Post Posted: Mon Feb 14, 2011 7:22 am
Yeah they only just nicked a inner seam but I think I could have chopped a little bit more and made it fit ;) . And if the offset was a bit smaller it might have been better.
Post Posted: Mon Feb 14, 2011 7:25 am
since its NPNP. but not my post, I will still put a pic on. This is the TD kit next to the 5 inch.. I didnt have the TD coil down a little bit to compare properly..
Post Posted: Mon Feb 14, 2011 7:28 am
Mhh yummy!
Start a build thread?
Post Posted: Mon Feb 14, 2011 7:32 am
any pic on flat ground on the side??, if you dnt have jsut take one.. I want to see the look of that :twisted:
Post Posted: Mon Feb 14, 2011 7:36 am
Hummm... Maybe. I don't have that many photos yet though. I'll see if I get bored one day and I might.
Glad you liked the kit. Still not sure what to do with it yet. It drove awesome offroad. (the little bit I done). So flexy..
Only really need to fix the coil and shock touching problem. Which could be diff rotation a bit or maybe space the shock away a bit with a longer shock bolt. Would like to see the ORA kit on to see what they have done.
Post Posted: Mon Feb 14, 2011 7:40 am
how bad is your front castor angle? Longer arms may fix the problem or maybe that why it's only the ORA kit is a 4.5" lift not 5" .
Post Posted: Mon Feb 14, 2011 7:47 am
Front castor is all good. Custom made arms for 5 inch. Its the back thats the problem...
Post Posted: Mon Feb 14, 2011 7:49 am
coils are so bendy in the back cause they are so big! I think maybe smaller ones like the TD kit with spacers, so there is not as much bow in the coil.
Post Posted: Mon Feb 14, 2011 7:50 am
Or get some ORA coil or D&G tuning 4.5"coils with spacers?
Post Posted: Mon Feb 14, 2011 7:54 am
yeah maybe, but thats what I need to see if they bow the same, .5 of a inch should'nt make that much different.
If you look up Big Red suzuki jimny in google you can see the same lift similar to mine.. I think its in the 4wd monthly old shed page... so you will have to wait for it to load the page haha.
Post Posted: Mon Feb 14, 2011 7:59 am
I have been browsing though some jimny forums from the uk and i haven't seen a single jimny with a 4.5" lift, they all seem to go with 3"spring lift and BL's from 1" up a 3"and i found one jimny with a 3"coil lift and 3"BL and he was only running 235's.
Post Posted: Mon Feb 14, 2011 8:02 am
That sounds like Squik's old Jimny.
kemlar wrote:
If you look up Big Red suzuki jimny in google .
stimpy??
and if you re keeping your lift, it wont be easy to get a custom arm for the back... or buy one from ORA, instead of the smaller coil + spacers idea
:please: more piiiiiiicsss.
ps start a built treath eh :wink:
Post Posted: Mon Feb 14, 2011 8:15 am
na not stimpy. Its a Jimny with the shed name as Big Red. You can find it in google search but not if you go through the 4wd monthly shed page. Its weird must be a old page that was deleted but still on the net some how. Yeah maybe I can make or buy another arm for the back. But I think the lift is still a bit big. I think the cops would prob just bend me over if they seen it.
PS : 3 inch coil lift with 3 inch body and only running 235s.... holy roll over!!
Post Posted: Mon Feb 14, 2011 8:18 am
YEH
NOW START A BUILD THREAD!
Post Posted: Mon Feb 14, 2011 8:34 am
http://www.4wdaction.com.au/gallery/366 ... 3438#image
Post Posted: Mon Feb 14, 2011 8:38 am
Looks good but, with a 5" lift i would have thought 31's or even 32's would of been better for that size lift, cus you can get 30's under with a 2" lift.
Thats the one. Thanks atari. Meant to be using the same coils I got but only running 30s.
Post Posted: Mon Feb 14, 2011 8:39 am
Yeah 31s were good. and better offset too. Maybe not as extreme as I used though.
Post Posted: Mon Feb 14, 2011 8:41 am
Personally if i was going 31's i would 2"bl and chop the gurads!
Post Posted: Mon Feb 14, 2011 8:46 am
Yeah and stab the airbags. Cause we are going all out on being illegal anyway haha.
Post Posted: Mon Feb 14, 2011 8:51 am
I was going to try get my car engineered with a Bl but now i have decided i don't want to go to 31's, so no BL for me.
Post Posted: Mon Feb 14, 2011 9:22 am
mmm kit like that means 33s, on my jim WIKED
dodgy brothers mechanical
Post Posted: Mon Feb 14, 2011 9:27 am
With standard gearing too, SICK!
Vehicle: Jimny
Post Posted: Mon Feb 14, 2011 9:32 am
thats awsome. do they fit with the three in a mass guard chop?
DONT BUY A GQ! zooks are better. i have both :)
Post Posted: Mon Feb 14, 2011 9:35 am
Sorry but that red jimny is no where near wide enough for the lift it has. 8O
White one on neg offset rims is more to my liking 8)
Post Posted: Mon Feb 14, 2011 9:36 am
X2
Vehicle: Jimny
Post Posted: Mon Feb 14, 2011 9:51 am
sorta thinking i might go 3inch s/l and 2 b/l
Users browsing this forum: Google [Bot] and 280 guests
