It is currently Thu Oct 22, 2026 4:38 pm
Post Posted: Tue Feb 15, 2011 7:45 am
Just wondering if the Calmini Kit for the SWB Vit's are interchangable with the LWB Kits
Stocker
Post Posted: Tue Feb 15, 2011 7:47 am
yes.
Vehicle: LWB Sierra & XL7
Post Posted: Tue Feb 15, 2011 7:48 am
I'm quite sure they are, after all they're the same chassis, just shorter.
'92 Vitara & Camper trailer
Post Posted: Tue Feb 15, 2011 8:02 am
kk, so its just the body lift that is different?
Stocker
Post Posted: Tue Feb 15, 2011 8:04 am
yeas, the SWB has 2 less fixed body studs = 2 less blocks & 2 less female bolts
Post Posted: Tue Feb 15, 2011 8:06 am
Cheers gus
Stocker
Post Posted: Tue Feb 15, 2011 10:28 am
Only thing to bear in mind of course is the bit of extra weight on the rear springs, may ride a touch lower.
Post Posted: Tue Feb 15, 2011 10:33 am
just replace all the glass with polycarbonate, should lighten it up a tad :D
It would be nice.
Vehicle: 96 LWB Vit
Post Posted: Tue Feb 15, 2011 10:59 am
I've found the springs on the back bottom out when fully loaded on my LWB.
Other than the weight factor, there's no difference.
Buddies
I can't leave well enough alone....
Post Posted: Tue Feb 15, 2011 11:00 am
when fitted to a SWB, the rear usually sits higher than the front, chop's LWB sits pretty level.
Post Posted: Tue Feb 15, 2011 11:07 am
Yeah mine sits heaps high at the back
Post Posted: Tue Feb 15, 2011 11:15 am
i permanently carry a box of tools/recoverygear/spares to add a bit of weight over the back axle to get some ride comfort back... probably 50kg, i don't run rear seats & it still sits a little high in the rear.
Users browsing this forum: AdsBot [Google], Google [Bot] and 109 guests
