It is currently Tue Oct 27, 2026 5:19 am
Vehicle: G16b 83
Post Posted: Tue Feb 15, 2011 9:30 am
where is the best and cheapest place to get an adaptor plate from
Post Posted: Tue Feb 15, 2011 9:31 am
right hear
http://auszookers.com/index.php?name=Fo ... ic&t=15009
Post Posted: Tue Feb 15, 2011 9:35 am
BEN T
My Maruti build, Click WWW
Post Posted: Tue Feb 15, 2011 9:44 am
xedent wrote:
BEN T
Yep, get BEN T..
Vehicle: G16b 83
Post Posted: Tue Feb 15, 2011 7:03 pm
so im picking up a baleno this weekend, will i have to get another clutch or can i use the baleno one ???
Post Posted: Tue Feb 15, 2011 7:52 pm
is this a conversion for a sierra?
Post Posted: Tue Feb 15, 2011 7:57 pm
Use Sierra flywheel, clutch and pressure plate....
You found one pretty quick 8O :lol:
Post Posted: Tue Feb 15, 2011 8:07 pm
BenT kit is fine if you are fitting a Vitara motor but Russty states in another thread he's using a Baleno...
I would use Petroworks kit as it includes full engine mounts.
Vehicle: G16b 83
Post Posted: Tue Feb 15, 2011 8:31 pm
yer cheap to can u think of anything else i will need
Post Posted: Tue Feb 15, 2011 9:22 pm
engine mounts...
Petroworks from Lowrange.
Post Posted: Tue Feb 15, 2011 9:36 pm
What is the difference between Baleno and Vit block? I've Never used a vit one only Twincoil Baleno..
Sierra cast engine mount holes were opened alittle to suit Baleno block, both holes in thin flat plates were moved (one slotted, one rebent so i could get a full new hole) so engine mounts sit nice and not twisted.
Stock Sierra box with stock Gbox mount.
Same adaptor should fit. Are the pins/bolts/location rings different?
I have also heard vits only need 1 flat plate mount modded, and some baleno motor people have only done 1 mount also.
Baleno motor can fit with no Bodylift, So lowering the motor like petroworks 'might' is not needed. (i havent looked yet)
AND carefully read through here, And if you click on the other link from outers, it will give you a list of items/mods you will need to do.
http://www.auszookers.com/index.php?nam ... 33&start=0
http://www.auszookers.com/index.php?nam ... pic&t=6423
http://forum.outerlimits4x4.com/viewtop ... lit=baleno
Since then^
I also used a 2L v6 vit airbox. and a camry airintake hose, Fit perfect. The 1L airbox was restricting.
Did you get ther twincoil pack model?
Post Posted: Tue Feb 15, 2011 9:58 pm
Or Holden vl rb30 ones
And thermostat housing from early 1.3 swift
Fuel pump etc
Read through this
What motor do you have now ? 1.3 or 1l
Vehicle: 85 SJ413
Post Posted: Wed Feb 16, 2011 4:18 am
My kit works fine with a Baleno motor, and given they have a lower intake manifold, you don't need a body lift, or lowered engine mounts.
Ben
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Users browsing this forum: No registered users and 233 guests
