It is currently Fri Oct 23, 2026 9:03 pm
Vehicle: Suzuki Grand Vitara
Post Posted: Wed Feb 16, 2011 8:58 am
I have a Suzuki Baleno and the blower is not working, does anyone know if the blower has a fuse in the dash fuse box or in the engine bay?
I had a look today and couldn't see a spot for the blower and there are no blown fuses.
The Baleno setup is simular to my Vitara layout and I couldn't find any reference to a blower/fan fuse with the Vit.
If the blower is not working is it a complete blower replacement?
Post Posted: Wed Feb 16, 2011 8:59 am
what psi are you trying to run mate ?
My Maruti build, Click WWW
Post Posted: Wed Feb 16, 2011 9:03 am
:lol: Not a engine blower, it is the blower unit for the heater unit.
Post Posted: Wed Feb 16, 2011 9:04 am
;) make sure you check all your fuses, pull them all out check them, and there might be more then one fuse box.
Post Posted: Wed Feb 16, 2011 9:06 am
i'd say the blower control resistors are gone.
Post Posted: Wed Feb 16, 2011 9:17 am
OK, so can you replace just the blower control resistors or are they part of the blower?
Post Posted: Wed Feb 16, 2011 9:21 am
does it work on the highest setting??
If it does it's the resistor block, if not I doubt it is..
Find the fan & give it a lil tap with the switch on full, if it goes again, get a new fan..
Post Posted: Wed Feb 16, 2011 9:22 am
are you sure it's not a fuse.....
the resistors "should" be replaceable... if not you should be able to cobble something up using various resistors from Jaycar.
Post Posted: Wed Feb 16, 2011 9:25 am
No doesn't work at the highest setting, will give it a bit of a tap and see what happens.
Post Posted: Wed Feb 16, 2011 9:29 am
I can't find any reference to a fuse for the Blower/Fan/Heater on the fuse cover inside the car or in the engine bay fuse cover.
All the fuses are ok and none blown.
Post Posted: Wed Feb 16, 2011 10:26 am
check if its gettin power to it.
Post Posted: Wed Feb 16, 2011 12:49 pm
X2 turn it on, and see if you have power to the fan. if not follow the wire back to the switch, and see if you have power there. If no power at the switch check fuse. I know you can't find a reference, maybe it is shared with another fuse?
Check all your fuses in any box you can find. I do this when I can not identify fuse locations. I have also accidentaly gotten other things to work by replacing fuses i did not know were blown, till i went looking :)
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 191 guests
