It is currently Tue Oct 20, 2026 2:42 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2
Post Posted: Tue Feb 15, 2011 9:21 pm
monkey wrote:
Just on the no rubber on the pedals thing, When i picked my jimny up from the dealer, there was no rubber on the accelerator pedal 8O
RWC only needs rubber on brake and clutch pedals, not accellerator.
I spose the theory is that your foot slipping off the brake or clutch could cause an accident but slipping off the accel pedal won't... :roll: :?
Post Posted: Tue Feb 15, 2011 9:23 pm
Ok thanks.
Post Posted: Thu Feb 17, 2011 7:50 am
I spoke to the Suzuki store and they said that the Sierra s never came with one on the accelerator but the guys at the pits didn't care what I had to say so I got one off a swift very similar shape and thy were happy with it
100 series cruiser 4 inch lift and 35s
1990 sierr
Post Posted: Thu Feb 17, 2011 1:26 pm
hey would i get my zook over the pits sitting on 31s ?
Post Posted: Thu Feb 17, 2011 1:28 pm
No! You are only aloud to go 15mm bigger than standard tyre size.
Post Posted: Thu Feb 17, 2011 11:51 pm
i got done in my dads r33 skyline for dark tint 5% so yeah very dark :D all we had to do to get the yellow licky off was remove the tint. they did not say anything about the huge exhaust or the wheels or the blow off valve. see i dont get how a sports car can have mods but a 4wd cant ??.
Post Posted: Fri Feb 18, 2011 12:04 am
Its most likely that neither of your sports car mods are legal. Just because it got through ok and they didn't pick up on it for some reason doesn't mean its a full legal ride.
Lil Foot!
Post Posted: Fri Feb 18, 2011 1:36 am
Pretty sure that's not the case in WA mate...
I want my old sig back :(
Post Posted: Fri Feb 18, 2011 2:02 am
you can only got 2" bigger than stock rim size
not too sure about the tyres tho
Post Posted: Fri Feb 18, 2011 10:29 am
Its most likely that neither of your sports car mods are legal. Just because it got through ok and they didn't pick up on it for some reason doesn't mean its a full legal ride.[/quote]
but the exhaust was quiet loud and they did not say a thing ?? guess time and place when going over the pits. i have only gone to miland apart from being close to me have heard too many bad things from the others.
Post Posted: Fri Feb 18, 2011 11:43 am
from: http://www.auszookers.com/index.php?nam ... hlight=215
alien wrote:
in WA its no more than 50mm lift INCLUDING tyre lift.
From the NCOP that WA follow: www.infrastructure.gov...eb2006.pdf from: www.infrastructure.gov..._ncop.aspx (page 20/71, section 4.10)
Modifications that result in raising the vehicle body greater than 50mm are to be carried out and approved in accordance with Codes LS7 and Code LS8.
LS7 - page 61 - point 1: Design of modifications that result in the vehicle body being raised by more than 50mm from the original "as manufactured" height.
Page 63: Wheels & Tyres - The overall tyre diameter can be increased by up to 26mm (four wheel drive vehicles only). Tyres fitted to commercial vehicles must not be more than 50% wider that the vehicle manufacturer's widest optional tyre.
The wheel track of off-road and four wheel drive vehicles must not be increased by more than 25mm...
LS8 - page 68 - point 1: Design of modifications that result in the vehicle body being raised by more than 50mm from the original "as manufactured" height. which includes points 6. installation of body lift and 7. alternative wheel and tyre specifications with modified axles or suspension.
So in essence.. a 215/75r15 is in fact ILLEGAL to run on a vehicle that has a stock 205/70r15 as its 35.5mm larger - exceeding the maximum allowed increase by 9.5mm, and running a larger tyre in combination with a lift of 50mm or more is also illegal.
Cool huh? =)
Users browsing this forum: Google [Bot] and 122 guests
