It is currently Sun Nov 01, 2026 11:01 am
Post Posted: Sat Feb 19, 2011 9:01 pm
hi all
im putting on my hard top and cant get 3 screws
what is the easy way to get them out
thanks matt
Post Posted: Sat Feb 19, 2011 9:08 pm
HOW TO
Post Posted: Sat Feb 19, 2011 9:21 pm
Haha as soon as I saw the title I was like someone would have put that tutorial up.
Post Posted: Sat Feb 19, 2011 9:38 pm
My fav trick of mine depending on the size of the screw is to use a dremel, put 1 slot straight across the screw head and unscrew with a flat head driver.
GT
Post Posted: Sat Feb 19, 2011 11:55 pm
GT
x2
That's never failed me.
Post Posted: Sun Feb 20, 2011 12:10 am
GT
x2
hacksaw blade or grinder for us povo's :P
I always seem to snap the screw head off doing it this way
Post Posted: Sun Feb 20, 2011 12:13 am
i use a air chisel and wants33s method.
Post Posted: Sun Feb 20, 2011 12:17 am
GT
x2
3x
I use a 1mm cutting disc in an angle grinder and a BFO flat blade screwy. I have one with a square shaft that you can put a shifter on. Works well.
Post Posted: Sun Feb 20, 2011 12:57 am
Just drill the middle of it out and use an easyout. :D
Vehicle: '94 suzuki maruti
Post Posted: Sun Feb 20, 2011 1:13 am
recently took off my doors, and want33s method works perfect. either way you need new screws.
Post Posted: Sun Feb 20, 2011 3:30 am
You've rooted the head, so just tack weld a nut onto the head and take it out with a socket.
Post Posted: Sun Feb 20, 2011 6:58 am
Hanner and cold chissel. works everytime. doesnt always leave everything intact but the screw/bolt comes out
Post Posted: Sun Feb 20, 2011 11:08 am
99% of screws removed by the method I detailed in the link are reusable.
No need to butcher them, you only need to crack it then undo with a large phillips.
Post Posted: Sun Feb 20, 2011 11:21 am
mine needed a little bit of convincing to turn... :( maybe i was just unlucky, or too impatient.
Post Posted: Sun Feb 20, 2011 11:25 am
I had a screw i had get out on Friday> It was a screw going though 2 real thin peaces of sheet metal, the head of the screw was fine but the thread was stuff just behind the head of the screw and it was just spinning, so got a old screw driver hit the head of the screw to bend it then it gripped and i got it out. :D
Post Posted: Mon Feb 21, 2011 3:58 am
mate i had the same trouble for the same job.
use a impact screwdriver gets em out straight away
Post Posted: Mon Feb 21, 2011 5:05 am
Heat the screw
Post Posted: Mon Feb 21, 2011 7:12 am
Not all way's, I've busted impact bit's & had to resort to the chisel trick.....
Even had to drill..
Post Posted: Mon Feb 21, 2011 8:34 am
thanks all
the chisel trick worked well how i just gotta move my roll bar because the roof was sitting in the bar
matt
Post Posted: Mon Feb 21, 2011 8:49 am
Even had to drill..
well it worked for me on like 3 diffrent screws
maybe just lucky :?
i have to admit on one of my old sierras it dident work so i grinded it off lol
Users browsing this forum: Google [Bot] and 397 guests
