It is currently Sun Oct 25, 2026 3:37 am
Post Posted: Sun Feb 20, 2011 8:14 am
does anybody know of any step by step guides on fitment of a auto locker into the rear diff of a sierra(WT leafy).
i feel confident i can do it, just wouldnt mind seeing it done by someone.
cheers
Post Posted: Sun Feb 20, 2011 8:18 am
Have a look in good tech section it has a couple of auto locker threads vitara front is the same aswell
Post Posted: Sun Feb 20, 2011 8:24 am
Just follow the instructions in the booklet provided.
Its very straight forward.
The hardest part is setting the backlash on the crown and pinion gears. I eyed it off, however probably best to use a dial indicator (you can find how to set backlash on the interweb). I've done 40,000km no issues at all, still working as good as when I installed it.
Post Posted: Sun Feb 20, 2011 9:14 am
http://auszookers.com/index.php?name=Fo ... ic&t=18000
if u drive a loud toyota ute u drink rum
Post Posted: Sun Feb 20, 2011 9:33 am
I haven't bought it yet. Was sorta just busting out of my skin with curiosity, as I'd gotten so many different opinions regarding difficulty.
I was made aware that there was no backlash adjustment on the auto locker install..
Post Posted: Sun Feb 20, 2011 9:38 am
there is, you have to remove thew hemisphere from the 3rd member, so you'll have to set the backlash again..
Vehicle: 2004 SQ625 GV
Post Posted: Sun Feb 20, 2011 10:49 am
When I fitted my lockright I checked the back lash before I took it apart then took it apart and fitted it back as per the manual . Checked the back lash again and it didn't change. So if you follow thier directions and and mark everything right you should be fine.
Post Posted: Sun Feb 20, 2011 10:55 am
Auto lockers are 1000 times easier to fit than Air lockers. Just mark everything as you pull it apart and put it back in the same place, easy as pie.
Suzuki is my way of life.
Vehicle: Yamaha scooter, 50cc
Post Posted: Sun Feb 20, 2011 1:03 pm
Check out this link
http://auszookers.com/index.php?name=Fo ... ic&t=15661
I've got a Spartan locker from lowrange in the states, delivered for under $200.
Super easy to install in the back yard with basic tools and bugger all mechanical knowledge.
It bangs and clunks at car park speeds on high grip surfaces (tar), but no noise at normal driving speeds and is excellent off road.
Post Posted: Sun Feb 20, 2011 8:18 pm
Yeahmight look at the Spartan locker then, good price!
Bought myself a dial indicator. So no biggy on having to adjust the backlash. Sorta why I wanted to ask now, as opposed to ripping my diff apart then realising I need to do it.
Good times. Thanks guys.
Users browsing this forum: No registered users and 92 guests
