It is currently Sun Aug 02, 2026 11:53 pm
Post Posted: Mon Jun 07, 2010 2:10 pm
G'day all, I've heard that people use fuel tank from vit SWB 1.6 carby model. It's 50l and with few mounting modification can replace factory one. Have anyone did this but without having body lift? I know that it would sit lower, but fuel tank can be protected by bashing plate. If that is possible to fit into sierra without BL, than is it easy to do it, like swaping them over, conecting fuel lines and hoses or there is more work involved?
cheers
Chris
Post Posted: Mon Jun 07, 2010 2:13 pm
hey mate,
cant help you out about the fitting questions, but i dont think it is a 50L tank, i have a swb vit but with the efi and its only 42L so i doubt the carby would be bigger, but i could be very wrong.
cheers
Mitch
Post Posted: Mon Jun 07, 2010 2:17 pm
i thought only the LWB vit tanks were bigger.
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Mon Jun 07, 2010 9:19 pm
I'm unsure of the size, but I know Taff put a Vit fuel tank
in his LWB, I'm not sure it the vit tank was efi/lwb/swb though. So
try PM'ing him and see what he has to say. 8)
Post Posted: Mon Jun 07, 2010 11:31 pm
thx guys, I'll try to check the size of the tank
Post Posted: Tue Jun 08, 2010 12:03 am
You have to remove all the 1.3 fuel tank mounts.
Make up one mount in the shock x-member, and make up mounts on the rear x-member (pipe).
Without a 2" BL it will sit a fair bit lower, and you may have some small issues of the fuel filler hose and chassis rail.
The fuel filler hose comes out the top, and may be a pain.
Other than that it would be fairly easy, but a BL makes it so much better. With armour plate over it, the armour has the same clearance as the stock 1.3 tank.
The other issue is theres a bit of fiddly exhaust work to route around the fuel tank. Some heat shielding will be worth considering too.
Attached is an EFI fuel tank, but you get the idea.
edit: pic stolen from here
http://auszookers.com/index.php?name=Fo ... ic&t=12203
Post Posted: Tue Jun 08, 2010 7:51 am
There's no point replacing a carby sierra tank with a carby vitara tank. The size is nearly the same so it's lots of work for no gain.
It's a good swap if you plan to go EFI as it avoids all the mess of lift pump/surge tank/feed pump in th load area.
The LWB tank is larger (55 litres rings a bell?) but it's wider so it will be a real pain to try and get between the chassis rails at the rear. It's also EFI only. Sure, you can delete the EFI pump easily enough, but I still think it would be a pain to fit.
Post Posted: Tue Jun 08, 2010 8:16 am
I think these figures are correct.
1.6 Carby ~ 42L
1.6 EFI SWB ~ 50L
1.6 EFI LWB ~ 55L
2.0 J20 ~ 60L ( SV420)
2.0H20 ~ 60L (SV620) ???
The 2.0L J20 tank is 25mm deeper than the 1.6LWB, but otherwise it is identicle. Both are about 700 mm long x 340 wide.
Post Posted: Tue Jun 08, 2010 8:22 am
I'm pretty sure 1.6 EFI and Carby are the same. I've had them side by side and they look identical but for the EFI pickup.
Could be wrong, but I'm sure I've never put anything like 50 litres in mine. Dead empty comes up at 35litres or so.
I agree the SWB 2.0 tank is taller.
Post Posted: Tue Jun 08, 2010 8:32 am
Fair enough. I haven't seen the two 1.6L SWB tanks side by side, so they are most likely the same size as you suggest.
I suspect that the 2.0 4 cyl, and 2.0 V6 tanks are the same though....
Post Posted: Tue Jun 08, 2010 9:41 am
thanks a lot for advice, as I see there is no point of replacing it with vit tank. I removed BL and don't want one. I'm not changing carby for efi, and for so much work and so little gain it looks like it's not worth the hassle. I wish ARB long range tank would cost at least 50% less, but they probably are only for LWB anyway.
I'll do a bashing plate over a tank and will live with jerry cans for longer trips:)
cheers
Chris
Post Posted: Tue Jun 08, 2010 9:48 am
the donor was my mated old vit, a LWB efi
Vehicle: Sierra
Post Posted: Wed Feb 23, 2011 1:13 am
Could someone please clarify for me:
For a SWB sierra, Leaf
Will a SWB EFI Vitara tank 50L fit between chassis rails and cross members?
And, A LWB EFI Vitara tank is 55L, will this fit between the chassis rails and cross members?
"Steve" has said it is tight, however I'm assuming it does actually fit?
Are there any other cheap EFI tank options?
Thanks
Dale
Post Posted: Wed Feb 23, 2011 1:21 am
Will a SWB EFI Vitara tank 50L fit between chassis rails and cross members? Yes. Needs all new mounts
Are there any other cheap EFI tank options? Yes. Coily tank, Vitara efi pump. Bolts straight in
Thanks
Dale
Post Posted: Wed Feb 23, 2011 1:43 am
the SWB EFI tank isnt 50l, only 42 like a sierra
Post Posted: Wed Feb 23, 2011 1:50 am
what are the mounts like in the way of differences between the 1.6efi and the j20 one?
Post Posted: Wed Feb 23, 2011 2:13 am
1.6 Carby ~ 42L
1.6 EFI SWB ~ 50L
1.6 EFI LWB ~ 55L
Whats stock un-molested sierra again? 42?
Lil Foot!
Post Posted: Wed Feb 23, 2011 2:47 am
Rare as rocking horse poo! 8O
:lol:
Should be 40L, same capacity as LJ80.
Clearance Hole Technology :P
Post Posted: Wed Feb 23, 2011 7:07 am
swb vit efi IS 50L. I measured it. Jug and water.
Post Posted: Wed Feb 23, 2011 9:33 pm
Owners manual says 42l, when mine is under empty it takes 38l, reckon your jug might be a bit off
Post Posted: Wed Feb 23, 2011 9:37 pm
I reckon your pump is screwing you. :lol:
Post Posted: Wed Feb 23, 2011 9:54 pm
by your logic, I am putting near on 50l in and getting charged for 38l, so my pump is either being nice to me or your maths truly does suck :)
Post Posted: Thu Feb 24, 2011 12:43 am
:lol: My maths has always sucked.
Post Posted: Thu Feb 24, 2011 6:49 am
Is you math single?? :P
Post Posted: Thu Feb 24, 2011 10:33 am
Hahaha. Stekky..... FYI "Math" is not the name of his cat :lol:
Post Posted: Wed Jan 25, 2012 9:43 pm
Just to clarify if possible. If I was to make up mounts in my car for a SE416 LWB fuel tank, and then bought either a SV420 or SV620 tank, it would bolt straight in as a straight swap, with the only side effect being the bottom would sit an inch lower?
Post Posted: Wed Jan 25, 2012 11:46 pm
I would get measurements then make the mounts.
I have a lwb 2Lv6 tank in my lwb, had to move the rear crossmember and it just fits between the rails.
This is a 1.6 swb efi vit
Post Posted: Thu Jan 26, 2012 12:07 am
I'll get some screen dumps of the TSOR tank guards in solidworks. Give me 10 mins.
Yeah I'll have to delete a cross member, and relocate a new one further forward. The Estate wagon tank just fits between the LJ's rails, and I might have room for an exhaust :lol:
Only reason I ask is I have an SE416 one I can borrow, and I'm bored and want something to do now! :lol: But don't want to chop it if I'm screwed later on :crazy:
Edit: Thanks pete, that would be appreciated! :)
Post Posted: Thu Jan 26, 2012 12:24 am
Ok, so my solidworks isn't playing the game, but here are some dimensions from my PDF's.
42L SWB carb/EFI vitara tank. ( same tank guard for both, so there is no such thing as a 50L SWB tank)
Bolt spacings.... Front flange ( closest to diff ) 455mm apart
Rear flange 480mm apart.
Tank body is approx 350 deep from front to back, and 700 from side to side.
55L 1.6 LWB efi tank
Bolt spacings.... Front 480mm
Rear 480mm
Tank body approx. 435 deep by 750 wide.
60L SV tank
Bolt spacing Front 480mm
Rear 480mm
Tank body approx 435x800.
From these dimensions, you can assume that the LWB efi and SV tanks will bolt to the same mounts. But you will need about 850-900mm between your chassis rails to get an SV tank in.
Hope this all makes sense :?
Users browsing this forum: Google [Bot] and 288 guests
