| Author |
Message |
89_tintop
Joined: Fri Aug 07, 2009 11:30 pm Posts: 3159 Location: gold coast
 Posted: Mon Sep 21, 2009 10:24 pm |
as the subject head sais.. it is a little sloppe when in gear, and when taking gear you have to put it heaps to the left to get it into 1st..
dont know if i dreampt this but does someone make/sell the little plastic bit on the end of the stick on this forumn if so who
steak_knife
 Posted: Mon Sep 21, 2009 10:54 pm |
Suzuki make em!!
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Mon Sep 21, 2009 10:59 pm |
89_tintop wrote: as the subject head sais.. it is a little sloppe when in gear, and when taking gear you have to put it heaps to the left to get it into 1st..
PM Bruce
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Tue Sep 22, 2009 12:20 pm |
Go to suzuki and get the shifter bush as well as a new bolt.
tanshi
 Posted: Tue Sep 22, 2009 1:05 pm |
my old man just got one from bruce.
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9717 Location: NSW
 Posted: Tue Sep 22, 2009 2:27 pm |
I made a steel one
Hybrid
Joined: Mon Apr 21, 2008 11:30 pm Posts: 1095 Location: Bulimba, Brisbane
Vehicle: '92 Sierra
 Posted: Tue Sep 22, 2009 7:55 pm |
x 2 on the bolt. I just got the rubber bush from suzisport.
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Tue Sep 22, 2009 11:18 pm |
i have used the guy from ebay that does the gearbox, transfer case and steering a few times and they work great.
if your gearbox is playing up most of the time the transfer case is stuffed or on the way out as well and worth the extra 5 min to do that.
zukenutter
Joined: Sun Feb 08, 2009 10:30 pm Posts: 9045 Location: Brisneyland
 Posted: Wed Sep 23, 2009 12:30 pm |
Yeah Bruce or any Suzuki shop. Fairly common item. A new bush will make it feel brand new again.
_________________ Click WWW below for STICKERS
lauby
Joined: Sat Dec 05, 2009 10:30 pm Posts: 254 Location: Gold Coast
Vehicle: 91 Sierra
 Posted: Wed Mar 02, 2011 9:14 am |
1990 maruti 4 speed gear stick needs help
want33s wrote: Go to suzuki and get the shifter bush as well as a new bolt.
Okay, i'm in the shed, have the replacement bits, the question is how do i get the new shifter bush on ?
The old one ( shown in pic ) has a split up one side so it just slipped off, the brand new one has no split  .... It won't fit over the ball at the base, and it doesn't fit over gear shaft / rubber boot etc from the top.
Before i break something, thought i'd ask here, cheers.
Fatzook
 Posted: Wed Mar 02, 2011 9:17 am |
From the top
Take the knob off ( unscrews) slide the boot, locking ring and washer off. Then apply some grease to the bush and slide on.
lauby
Vehicle: 91 Sierra
 Posted: Wed Mar 02, 2011 10:10 am |
Thanks FZ.
 easy once you know how. The shifter bush did stretch a little to get over the thick part of the gear stick but it survived intact
It took me longer to do the post above than it did to actually replace the bush and bolt gearstick back in. Massive improvement ! $22 for bush, $6 for bolt = bran new box
Fatzook
 Posted: Wed Mar 02, 2011 10:25 am |
Bruce
Joined: Sun Jun 11, 2006 11:30 pm Posts: 4003 Location: Brisbane
 Posted: Wed Mar 02, 2011 5:57 pm |
$22 for the bush WOW. I'm selling too cheap
_________________ [quote="royce"] I wouldnt mind insulating my rear
cairns27
Joined: Thu Dec 23, 2010 7:42 pm Posts: 489 Location: Macleay Island
 Posted: Wed Mar 02, 2011 6:19 pm |
I did this about a year ago, and it only half fixed it.
suzisport just said make sure I line it up with the locator, does a new bolt make that much difference.
bye
lauby
Vehicle: 91 Sierra
 Posted: Wed Mar 02, 2011 8:28 pm |
cairns27 wrote: suzisport just said make sure I line it up with the locator, does a new bolt make that much difference.
You can see in the last picture, the old bolt next to the new. The old bolt had almost worn away to nothing. When tightened the bolt end slides into a slot on the ball at the base of the gearstick, nice tight fit now with the new bolt.
