It is currently Wed Oct 21, 2026 11:55 am
Post Posted: Tue Mar 08, 2011 3:58 am
Hi - I just found out that a Swift starter motor doe's not fit when you mate the G13a motor to a 5 speed box so need to find one that does.
I am in Western NSW so would need post. Cheers - Tony
Post Posted: Wed Mar 09, 2011 3:33 am
I also need a Radiator - Fan - Surround please - Tony
Post Posted: Fri Mar 11, 2011 1:35 am
OK - Have now got the starter, Radiator and surround on the way but still need the Gear-stick for the 1.3lt 5 speed box and a fan.
Cheers - Tony - out west (a long way)
Post Posted: Fri Mar 11, 2011 10:29 pm
Now I have found that the Radiator connection on the manifold is on the wrong side (Back instead of front) so now need an intake manifold - Tony
Vehicle: Suzuki Sierra
Post Posted: Thu May 05, 2011 10:46 am
would a manifold from a 88 1.3L engine fit on it?
SierraFreek!
Post Posted: Thu May 05, 2011 12:49 pm
yes
Post Posted: Thu May 05, 2011 1:19 pm
I have a fan, I believe is 1.3, tho a 1.0 litre fans fit, too.
I don't have mounting bolts or the aluminium boss/spacer thing.
It looks rough, let me know if you want it.
I busy till next week, then can post it if you like.
Swift engines often use a thermo fan,
the water pump pulley sometimes don't fit a Sierra fan.
I used an adaptor on my swift donk, to fit a Sierra fan,
but that got sold yonks ago.
christover
Post Posted: Fri May 06, 2011 3:24 am
1L Fan ^
1.3 Fan v
Post Posted: Fri May 06, 2011 3:52 am
I remember now,
I switched to 1.0 fans because all my 1.3 fans kept breaking.
Not sure if there was a reason.
My 1.3 always ran cool enough with either type.
Post Posted: Sat May 07, 2011 2:04 am
Tony,
I have a spare inlet manifold, but as we discussed a while back, I have opened it up substantially, where the carby bolts on as stock, the throat openings have a combined flow area of 1231mm2, where mine has around 2000mm2
Now stock fans, but a nice selection of thermos.
Post Posted: Sat May 07, 2011 3:50 am
SuziBlu wrote:
Tony,
I have just got hold of a manifold but has a bolt snapped of in one of the thermostat housing holes and someone has butchered it a bit so I don't know if I will be able to get it out. I will try over the weekend.
Now I have never used thermo fans at all so tell me about them and don't you need some sort of controller set-up with them?
Tony
PS - Mums Opal left today :lol: Hope she likes it
Post Posted: Sat May 07, 2011 4:08 am
Post Posted: Sat May 07, 2011 7:54 am
Tony I have a 1.3 manifold you can have for free. A fan you can have with spacer for $15 and $20 post.
NB: Sierra fan won't fit Swift/Barina water pump.
Users browsing this forum: No registered users and 17 guests
