It is currently Wed Jul 29, 2026 9:59 am
Post new topic Reply to topic  [ 58 posts ]  Go to page 1, 2  Next
Vehicle: LPG 1.6 Sierra
Post Posted: Sat Mar 12, 2011 1:22 am
Who knows stuff about inverters? Looking to get something to power a laptop, a portable hard drive, and a camera battery recharger all at once.
Just wondering if you're supposed to match the inverter with the draw of your gear, or to get the max possible wattage you can afford?
Any tips and advice appreciated
Vehicle: Vitara
Post Posted: Sat Mar 12, 2011 1:34 am
Hope this helps..
http://www.invertershop.com.au/power-in ... guide.html
Repping it, High Top style!
Post Posted: Sat Mar 12, 2011 1:35 am
work out the total draw that will be on it at any given time...
then go for one that is larger then that (i would go as large as I could afford/space would allow)
Post Posted: Sat Mar 12, 2011 1:49 am
A have a 300 watt inverter with a 600watt peak, can run a drill or a small grinder, will charge a laptop, phone, and on the packet it said it will run a small t.v. to.
Vehicle: Suzuki
Post Posted: Sat Mar 12, 2011 2:56 am
At a guess;
Laptop 80-100W
Hard Drive 10-20W
Camera Charger 10-20W
Post Posted: Sat Mar 12, 2011 3:08 am
they will all say the current draw on em, add em up and get the next size bigger :)
its best to get something that you can return as well, I believe some things dont like some inverters
Though I dont like converting voltage to covert to another voltage, ebay 12v laptop supply are cheap and mine at least works well, maybe you hard drive and charger will run from 12v anyway
Post Posted: Sat Mar 12, 2011 3:30 am
I saw a 300w inverter at Jaycar earlier for $70 which isn't too bad a sting, but they were run off their feet and I didn't have time to wait around to ask them a few Qs.
Might go back and snap it up.
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Sat Mar 12, 2011 5:04 am
for running lots of special electronics like these go for a pure sine wave inverter, will cost a fair chunk more but the ac output is of much better quality
'88 Tin Top Sierra, '95 JX Vitara Estate
Go hard,
Vehicle: Jeep
Post Posted: Sat Mar 12, 2011 6:21 am
I was in Ray's Outdoor yesterday, they have a 600w for $99... i nearly bought one... but wasnt sure about how much i could run off it... but if a 300w will run a drill, i might go for 600w, just for that added extra.. wonder if it will run off a standard 10amp ciggy socket... :wink:
Hmmm so a standard inverter isnt to good for electronic items... might have to factor that in as well... AZ is full of useful info ! :D
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Sat Mar 12, 2011 6:22 am
X2
Much less chance of damaging your equipment.
Post Posted: Sat Mar 12, 2011 6:25 am
depends on how many watts the drill is :)
then you need to double it for start up current, so 900w might be good
then 900w plus 20% for losses in teh inverter = 1080w
1080w / 12v = 90 amp, aint getting that from any socket :wink:
just get a cordless drill
Vehicle: Jeep
Post Posted: Sat Mar 12, 2011 6:40 am
Ahhh ok... well its gonna need its own dedicated power supply... yep i have a 14.4v cordless drill that i carry in the back of the GV, would just be nice to know i could use a drill with grunt and speed, or even a grinder, if i had too.... but no biggy... i like to prepare for the worst, or those unseen and surprising happenings when one is furthest from help, Murphys Law.... :lol:
Post Posted: Sat Mar 12, 2011 6:43 am
Without sine wave, your lap top will probably not run, many gensets I have seen cannot power a laptop.
get a cordless grinder that uses that same battery as your drill, its good being able to cut stuff up in the middle of a paddock :)
then a smaller inverter that will charge your batteries is the way to go :)
Post Posted: Sat Mar 12, 2011 7:35 am
Whatever you get just make sure you put a fuse the lines :oops:
Post Posted: Sun Mar 13, 2011 8:42 pm
Just run your cordless drill off the car battery, works fine and heaps of poke ;)
Post Posted: Sun Mar 13, 2011 8:53 pm
How, besides its different voltage, how do you hook it up.
Post Posted: Sun Mar 13, 2011 11:34 pm
I live in a remote area with solar and inverters 24/7 and run everything of them.
Your laptop would be better using a cheap 12 laptop power supply from Ebay as the first thing your 240 volt AC power supply does is convert it to low power DC anyway.
Same with your HD Power supply and most camera/battery chargers.
I would recommend a 12volt laptop supply and a 150watt plug in inverter from Ebay about $30 the lot.
Tony
Post Posted: Mon Mar 14, 2011 12:13 am
Laptops are fine on both square wave & modified square wave - most computers are - that's what most small UPSs deliver - APC, BEST, MGE, Minuteman, Powerware, TrippLite - pick a manufacturer, they all have them.
The hard drive and the charger will probably be just fine, most of them use switching power supplies (same as the computers).
Vehicle: 2010 Suzuki Swift Sports
Post Posted: Mon Jun 06, 2011 4:03 am
There is nothing wrong in using a stepped sine wave as the laptop power supply filters out any noise.
Most things you use with a plug pack use a switched regulator which is noisy anyway :)
I am looking at doing a group buy on these if anyone is interested:
http://www.jaycar.com.au/productView.as ... rm=KEYWORD
I will be able to get them for under $300.
Post Posted: Mon Jun 06, 2011 4:09 am
Errrr WTF??
Cordless drill is 14.4VDC. Car batt is 12-14.4ish volts. No issue. How do you hook it up: disassemble the drill and solder up 2 fly leads to where the battery would go with battery clamps, done.
Lil Foot!
Correct!
Lil Foot!
Post Posted: Mon Jun 06, 2011 5:19 am
What Royce said.
I have one for my laptop and works fine. Jaycar, DSE sell them.
They are a lot more power efficient compared to an inverter as well.
2002 SWB GV
Lifted and Locked
Post Posted: Mon Jun 06, 2011 5:38 am
I brought a inverter from Jaycar and it was dead from the box - I took it back to the dealer a mate of mine - he sent it back and because there were some little scratches around the mounting holes (It was a wall mount one) they said it had been miss treated and the warranty was void.
I was $800 out of pocket and would never buy anything from them again - Tony
Post Posted: Mon Jun 06, 2011 6:02 am
I don't buy from Jaycar, I buy from the wholesaler and use a rep to buy things through (hence the better than normal trade prices). I have been doing business with them for 10 years and haven't had any issues! Sounds like you got a bit of a retard manager.
Post Posted: Mon Jun 06, 2011 7:39 am
A good mate of mine is a 'leco. When asked about inverters he stated what royce stated and that is stick to 12v (and utilise the alternatives).
Admittedly he did buy one recently for his camper trailer. 2000w straight up. When asked why he needed something so big he responded "I hate maths'. On a side note he has also fitted an 'endless air' compressor with air tank. He is preparing to trek the Simpson desert.
Post Posted: Mon Jun 06, 2011 8:06 am
I buy from Electus Distribution, Jaycar's wholesale arm.
Granted most of their stuff is good quality I find their consumer-orientated stuff a bit low quality.
2002 SWB GV
Lifted and Locked
Vehicle: Jeep
Post Posted: Mon Jun 06, 2011 3:00 pm
I am not one to just sit back, and take that from them, and have them say that to me... i would get on to the state manager and create hell... its just not good enough mate... they are just one store, the onus is on them to prove you miss treated it... dont take shit from them, contact the state manager, and say you will take it to Fair Trading if its not sorted out ! :twisted:
Vehicle: WR250F/Jeep XJ
Post Posted: Tue Jun 07, 2011 12:34 am
We were joking about running a 5000W inverter and then using it to power an electric chainsaw for a joke out in the bush..
LIKE US ON FACEBOOK - KPD4x4
Post Posted: Tue Jun 07, 2011 8:39 am
i got one of them aswell. jacar sell em to if ur not a big ebay fan. i got an inverter aswell but thease lil power pack things are much more efficient for running the laptop.
THINKING BEFORE POSTING!!!
Users browsing this forum: No registered users and 504 guests
