It is currently Mon Sep 21, 2026 1:09 pm
Post Posted: Sun Mar 13, 2011 9:19 am
i joined the dark side today...i got a coily :twisted:
anyway it came with 2"body and 2"spring lift and 31's ....also a box full of rockhopper gears from bbm.
my problem is he said these gears are for a leafy :x
will theses fit into my coily transfer case?
or
should i put these in my sj50's transfer case and put that into my coily ???
thanks guys
Sj80,31 claws, lift, winch, 6.5
Post Posted: Sun Mar 13, 2011 9:21 am
you will need a leafy case,leafy jackshaft and mounts and it will be all systems go. should be a good car with that in it too 8)
Vehicle: Daisy
Post Posted: Sun Mar 13, 2011 9:27 am
wtf I must not have clicked post, I posted pretty much the same thing as you just did!
Oh well, looks like he's got all the info he needs now, check out my warning thread about rebuilding a transfer case before you go for it, make sure you have everything you need before you start!
It should be pretty easy though since you won't have the case in/out of the car before you start, so you can still drive while you do the rebuild!
Post Posted: Sun Mar 13, 2011 9:36 am
Make sure you have wide track leafy flanges, they are the same as coily. Other than that, it is a direct bolt in like appsie said. If you can afford it do all the bearings and get the updated output shaft. Then you will never have a problem :wink:
Nothing wrong with coily's either. Check all the mounts on your diff's and the mounts around the front struts :roll: at the top. Known weak spots
Post Posted: Sun Mar 13, 2011 9:43 am
thanks guys ...i have a 88 w/t sj50 so the stock cradle and cas will bolt straight in ? i just want to clear things up
Post Posted: Sun Mar 13, 2011 9:49 am
being a 88 if it is like my other set hear then the flanges will still be NT spacing not WT
Post Posted: Sun Mar 13, 2011 9:52 am
which means its a no go ?
Post Posted: Sun Mar 13, 2011 10:03 am
It's a 50/50 chance. There was a change over mid yearish. Early had NT later have WT flanges. It's not a big deal, just get some WT flanges. Just do a quick measure on the flanges and see
Post Posted: Sun Mar 13, 2011 10:24 am
any one have wt measurments????????
Post Posted: Sun Mar 13, 2011 10:26 am
60mm centres on holes
youll know there also a bigger hole.10mm not 8 like nt
Post Posted: Sat Mar 19, 2011 11:33 am
so i have nt flanges where can i pick up wt ones?
Vehicle: Daisy
Post Posted: Sat Mar 19, 2011 8:27 pm
I thought you could just use the ones off the coily case when you pull it out? All you NEED is the jackshaft.
I could be WRONG though, someone else here will correct me if that's the case.
Post Posted: Sat Mar 19, 2011 9:21 pm
That is a good suggestion mate. I'm not 100% sure if the output/input shaft diameter is the same, or splines are different. I didn't even think to check that when I did my transfer swap into my coily :roll:
Vehicle: Daisy
Post Posted: Sat Mar 19, 2011 10:18 pm
We've got a NT case to put into anto86's coily, he got the jackshaft to go with it, but it's missing one flange (not that it matters because NT are useless anyway. But we were planning to just swap the flanges over, at least that i the plan anyways...
Post Posted: Sat Mar 19, 2011 11:59 pm
Let me no how it goes:)
Post Posted: Sun Mar 20, 2011 12:48 am
Can ya put some pics up after you've put the new transfer redrocketsj50?
helloo
Vehicle: Daisy
Post Posted: Sun Mar 20, 2011 1:10 am
He wants to get it apart and acid wash it to clean it all (it's as filthy as mine was but I used a wire brush for an hour and a half on mine, he can get the acid bath done for free...)
Then put in the new gears that haven't even been ordered yet, then put it in the zook.
So a while yet but will let you know.
Post Posted: Sun Mar 20, 2011 1:20 am
What ratio is he getting??
Vehicle: Daisy
Post Posted: Sun Mar 20, 2011 1:29 am
I think he's decided on 4.9's
He's only on 235/75/15's same as me, but I plan to go to 31's so I put 6.5's in. Anto86 reckons they are too short for his liking so thats why the 4.9's.
Post Posted: Sun Mar 20, 2011 1:32 am
Fatzook has a brand new set of 6.5's for sale, and want33's has a wt case with installed already :wink: Don't quote me on it but I think fatzook wants around the $580 mark and want33's around $600
Users browsing this forum: Google [Bot] and 137 guests
