It is currently Mon Sep 21, 2026 1:47 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
Post Posted: Thu Mar 24, 2011 12:30 am
Back again
Ignition this time
is this enough crank wheel trigger to run 2 wasted spark coils on a 4cyl engine :)
36-1 wheel as used on Fords.
Yes this will let you run wasted spark using Megasquirt, Ford does the same thing with their EDIS system.
Post Posted: Thu Mar 24, 2011 12:43 am
thats actually made to use the megajolt EDIS setup on a mini, but I am not sure if I am keen on the EDIS as the modules and coils arent native in Australia I think
some generic Bosch stuff would be nicer I think
Post Posted: Thu Mar 24, 2011 12:59 am
It has some other limitations too, from memory you can't adjust the rev limiter with EDIS. And as you say, it would be better to use bits that are easily available.
You should be able to get pretty solid timing with that 36-1 wheel, compared to the 'ole dizzy driven off the camshaft.
Post Posted: Thu Mar 24, 2011 1:02 am
yeah I was jsut reading the rev limit part and they make a board that cuts power to the coil or a soft limit that set timing to 0 degrees, I guess you could just map your timing to as much retard as possible as well
the megajolt is $169, plus edis gear so its not much cheaper than a megasquirt anyway
Post Posted: Thu Mar 24, 2011 1:25 am
Hay Damo!
Can you tell me how wide the PCB tracks from the coil/injector drivers are on your board?
Lil Foot!
Post Posted: Thu Mar 24, 2011 1:38 am
JrZook wrote:
Hay Damo!
I'll have a look for you, but there will only be injector drivers on my version.
Post Posted: Thu Mar 24, 2011 1:44 am
Damo wrote:
JrZook wrote:
Hay Damo!
Yea no probs, just would like to get an idea and also the main 12V and 5V feed tracks
Lil Foot!
Post Posted: Thu Mar 24, 2011 2:07 am
So one of these
http://www.diyautotune.com/catalog/mega ... p-119.html
is the good value option?
I note this
Ignition control (full spark timing advance control, dwell control, etc) for one coil/distributor (7 pin HEI for example) and Ford's EDIS systems
So I need to run an EDIS if I dont want a dissy?
Post Posted: Thu Mar 24, 2011 3:10 am
So one of these
I note this
Yep that kit would do the trick. Send them an email, Matt is pretty quick with responses and very helpful. Tell him you want to run wasted spark for a 4 cyl with that kit and see what he suggests. The reason being is that kit has a single ignition driver, and you'll need 2 for wasted spark. he'll probably suggest to fit a 2nd driver in the proto area of the board. They supply all those extra components so you should be able to order it all in the one hit, makes it easier.
You don't need to run EDIS if you dont want a dissy, you can but there is more than one way to skin that cat. The way I would go is a 36-1 wheel like the one in the pic you posted earlier, 2 ignition drivers on the board and a coil pack like this kinda thing
Just rat around the wreckers and find a latish model donor with the same kinda thing, and make sure you get the wiring plug with it.
Post Posted: Thu Mar 24, 2011 3:18 am
After typing that I thought I can have a dissy, its jsut spreading the spark not doing any trigger stuff so its not important that its any good
Post Posted: Thu Mar 24, 2011 3:29 am
Yeah you could do that, though you'd be less cool :lol:
Getting rid of the dissy would be a good thing on a mini, they're not exactly in the best spot when it comes to water. Obviously it's less of a concern on a Sunday driver like yours.
Post Posted: Thu Mar 24, 2011 3:36 am
Ill get a photo later of the the ice cream container lid I jammed between it and the grill to drive to Willowbank last Sunday, it pissed down all the way there and back :)
Post Posted: Wed Apr 06, 2011 12:14 am
JrZook wrote:
Damo wrote:
JrZook wrote:
Hay Damo!
What he said :helloo:
Also what size wires does your megasquirt use, to injectors, ignition, ground etc
Lil Foot!
Users browsing this forum: No registered users and 103 guests
