It is currently Fri Nov 13, 2026 2:12 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2  Next
Post Posted: Fri Mar 25, 2011 11:15 am
I grabbed a 5m roll of SMD LED's, waterproof to IP65 with 120 LEDs per meter off ebay, some clear bong tubing & condute saddles from Bunnings, wire, silicone, terminals etc I already had.
Measure twice cut once...
Measure & cut LED strip to length & cut a length of tubing a bit longer. The LED's can be cut down in groups of 3.
Tape a piece of wire to the end of the LED strip & start feeding it into the bong tubing. Be gentle when pulling on the strip...
Trim back the silicone to reveal the solder tabs & solder on your wires.
At this stage I test to see if it works...
Wrap a few turns of tape around the soldered end to make a bit of a bung to stop the silicone spreading. Now pull the feed wire so the LED strip is poking out the end, un tape it & GENTLY pull the power wire end back so the LED strip is just inside the open end & feed a dob or 2 of silicone in the end to seal it.
With the power end I pumped a bit of silicone in til it fills up.
Let silicone to cure overnight... :wink:
I then made a set of "caps" out of irrigation poly pipe by sliding it over the bong tubing & filling them up with silicone.
Mount them where ever you can fit them, wire them up using a relay & fuse... and marvel at the extra layer of rice added to you 4wd, now just get some NOS seat covers & some blue valve caps & the Hot4's crew will be envious.
Post Posted: Fri Mar 25, 2011 11:21 am
Nice job!
And fark they are bright.
Post Posted: Fri Mar 25, 2011 11:22 am
:goodjob: Gus....it was a bit late for the Madi Gra though isn't it :finger: :finger: :finger:
Post Posted: Fri Mar 25, 2011 11:24 am
monkey wrote:
Nice job!
that is a long exposure.... but yeah they're bright enough!
Post Posted: Fri Mar 25, 2011 11:27 am
I'm preparing for next years.... you do know I'm towing you're coily as the float. DM90 and you are the King & Queen, you can decide who's going to be who. :lol:
Post Posted: Fri Mar 25, 2011 11:30 am
We can both be Queens pompoms pompoms pompoms
Post Posted: Fri Mar 25, 2011 12:52 pm
great idea mate will give it a go wth me camper trailer
Post Posted: Fri Mar 25, 2011 6:33 pm
:helloo:
You forgot the link to the light's so we all can copy you.. :D
Post Posted: Fri Mar 25, 2011 7:25 pm
can you get a pic of a 3 led piece lit up?
Post Posted: Fri Mar 25, 2011 8:13 pm
Awsum job mate will be doin sumthing similiar on mine
built not bought
Post Posted: Fri Mar 25, 2011 8:17 pm
thats a good build there.
What did it cost all up?
255 characters
Post Posted: Fri Mar 25, 2011 8:29 pm
steak_knife wrote:
:helloo:
Had a bit of bong hose left over, had to use it, an forgot. kewllll
Vehicle: 1985 Holden Drover
Post Posted: Fri Mar 25, 2011 9:37 pm
Looks mad mate! Looks simple enough too :)
1989 WT Sierra.
Post Posted: Fri Mar 25, 2011 9:43 pm
http://cgi.ebay.com.au/600LED-3528-SMD-White-5M-Flexible-Strip-Lamp-Light-Car-/220744184101?pt=AU_Car_Parts_Accessories&hash=item336560f125
Is that the LED strip you used?
Post Posted: Fri Mar 25, 2011 10:22 pm
tim80z wrote:
Bloody hell, 14-24 working days airfreight to oz.
Post Posted: Fri Mar 25, 2011 10:31 pm
tim80z wrote:
I'd be more inclined to get the 300 led 5m job they seem to be bigger led's, also that one you put up aint waterproof.
Post Posted: Fri Mar 25, 2011 10:33 pm
Chop wrote:
tim80z wrote:
I'd be more inclined to get the 300 led 5m job they seem to be bigger led's, also that one i you put up aint waterproof.
i thought that was why he put them inside the bong tube??
Post Posted: Fri Mar 25, 2011 10:44 pm
Maybe, I'd say its more for protection under the car and the fact you cant use the sticky back to stick to a chassis :wink:
If you buy the waterproof stuff you can use it elsewhere and just stick it without putting it in tube.
Post Posted: Fri Mar 25, 2011 10:45 pm
shandy92 wrote:
Shhh, I think chop had a hard night, he isn't fully awake yet, still on his first cuppa. :lol:
Post Posted: Sat Mar 26, 2011 1:51 am
The bong tubing is for an extra layer of protection from mud, rocks & crap not to waterproof the LED's... plus now I'll never have to cut down my garden hose again.
I bought the smaller LED's by mistake, I just saw the 120 per meter & went buy now. The larger ones would have been better & mega bright, the small ones would make awesome interior lights, camper lights, lights in rear storage units.
Cost = ummm about $80-90 depends on how well stocked the workshop is, LED's were $60, $8 for the tubing, $4 for the condute saddles... the other stuff I had already, wire, solder, tape, silicone, cable ties etc.
I've got a few little left overs, I'll wire them up & try to get some photo's.
Post Posted: Sat Mar 26, 2011 2:50 am
Nice 8)
Post Posted: Sat Mar 26, 2011 4:00 am
nice job...
just added another thing to he list of stuff to do.
to really rice it up.. make em come on when you open the door.
Post Posted: Sat Mar 26, 2011 12:24 pm
Awesome DIY mate i will def add this to my zook for night wheeling. Would the larger LEDS be better?
Brighter is always better.
Conrad
I HATE CYCLISTS!!!
Post Posted: Sun Mar 27, 2011 9:17 am
rice job mate
nice* :P
Post Posted: Sun Mar 27, 2011 1:18 pm
:helloo: :helloo:
yess!! yess!! yess!! pompoms pompoms pompoms
nice job there mate,
i will do something similar also
Post Posted: Tue Mar 29, 2011 1:39 am
3 led's = 25mm
looking in down next to the battery
in the washer bottle :crazy:
random hole in bonnet
about a foot off the ground
Post Posted: Tue Mar 29, 2011 2:14 am
:goodjob:
Post Posted: Tue Mar 29, 2011 4:21 am
They look pretty well powered for the smaller ones! DO WANT!
1989 WT Sierra.
Vehicle: 91 sierra
Post Posted: Tue Mar 29, 2011 5:53 am
love the idea of putting them in a tube, i didn't think of that when i did mine :(
doing them off the door is pretty easy going, i put those ones you have on the roll bar of my suzi and wired them plus another strip attached to door itself for door to come on when the door does.
under mine i used hard plastic 3 colour strip leds of 30cm long, glued to a plastic u channel,
they also turn white but i havn't got a pic of them white atm
this one you can kinda see the leds on the roll bar
how long have you been running your in that tube, cause mine heat up alot and i was wondering how your coped inside that sealed tube??
K.I.T
Knight rider
d(^_^)b
Users browsing this forum: Google [Bot] and 11 guests
