It is currently Sun Oct 25, 2026 3:36 am
Post Posted: Tue Mar 29, 2011 6:54 am
I had this idea which to me thus far seems good. And I thought I'd check with the experienced and advanced minds of AZ members on their opinion.
So, I have a 1ltr transfer which I need to do the seals on then is ready to swap. As well as the 1.3 transfer currently in my zook. And I am getting reduction gears when I can afford them. 4.9 are pretty much bang on what is necessary for me. But I can forsee times where I would definitely like/prefer 6.5s. The only problem I have with 6.5s is the VERY occasionally (1-3 time a year) I travel a few hours for a holiday of some sort and doing 80 the whole way would be painful.
So I was thinking having the 6.5s in 99% of the time. And swapping the 1ltr in for the long travel.
Good or stupid idea?
Post Posted: Tue Mar 29, 2011 7:03 am
If your running 31's with 6.5's it would be fine. I have 6.5's with 30's and still sit on 100 on the highway reving at about 4100ish. Stuff changing transfers to do a holiday drive :( In saying that it wouldn't be to bad if you were only doing the change 2 or 3 times a year i guess.
Post Posted: Tue Mar 29, 2011 7:07 am
Hmm, i thought 31's would be around 80 and 3500rpm..
then maybe i wont. ill use the 1ltr till i get 6.5s then sell it.
Vehicle: Daisy
Post Posted: Tue Mar 29, 2011 10:32 am
My 6.5's with 29's put me at 3800rpm for 100km/h
just over 4000rpm for 110km/h, I'd have to check, but my zook doesn't like 110km/h anyway, gotta be foot to the floor, it likes 100 though, can cruise at that with bugger all pedal...
Post Posted: Wed Mar 30, 2011 12:22 am
6.5 gears will drop your high range by about 20% from stock. A 1ltr case will drop high by about 12%
The 4.9 gears you want to get sit somewhere in the middle at about 16%
If i was in your shoes id go for the 6.5's. Low range is so much better and easier on your clutch and your revs are up only a few hundred when on the HWY which is good when you have bigger heavier wheels and stuff on it.
Post Posted: Wed Mar 30, 2011 12:38 am
Maby its just me but i find that i cant find the right gear for sand work running 6.5s and 31s .. and the stock 1.3
Post Posted: Wed Mar 30, 2011 1:40 am
what you prob lack is the extra HP.
Post Posted: Wed Mar 30, 2011 1:44 am
my 5th low gear is about the same as 1st high. 6.5s and small 31s
Post Posted: Wed Mar 30, 2011 1:45 am
Okie dokie then. I'll get the 6.5s and a full exhaust and I should be right!
Cheers for the insight.
Users browsing this forum: No registered users and 97 guests
