It is currently Tue Nov 03, 2026 10:16 am
Vehicle: 1985 Holden Drover
Post Posted: Wed Mar 30, 2011 7:38 am
Hey guys im looking at grabbing this front diff from an early 90's zook but all i need is the diff centre to replace mine in the rear of my 89 WT.
My question is will it be a straight in fit? Cant find much using the search either sorry :(
*EDITED* forgot to note down rear, to much working and not enough thinking! :P
Post Posted: Wed Mar 30, 2011 7:45 am
Yep :wink:
Post Posted: Wed Mar 30, 2011 7:56 am
Some people saying yes the others saying no?! Uber confused atm!
1989 WT Sierra.
Post Posted: Wed Mar 30, 2011 8:00 am
front or rear for sale, & which are you replacing??
Post Posted: Wed Mar 30, 2011 8:02 am
You posted in the VITARA wrecking thread so I thought you wanted a Vitara diff.
Not that I can help with a rear WT centre at the moment anyway....
Fronts for sale and rear needs replacing.
Heres the link to the post.
http://auszookers.com/index.php?name=Fo ... ic&t=20318
1989 WT Sierra.
Post Posted: Wed Mar 30, 2011 8:03 am
Haha just went and checked and very true i did :lol:
Sorry about that :oops:
Vehicle: Zookless
Post Posted: Wed Mar 30, 2011 8:05 am
If you're buying a front diff to put the centre in your rear diff - don't.
The front and rear axles are different. They have different spline counts.
Post Posted: Wed Mar 30, 2011 8:06 am
What he said.... :D
Post Posted: Wed Mar 30, 2011 8:07 am
God dammit....
1989 WT Sierra.
Post Posted: Wed Mar 30, 2011 8:14 am
abclarke wrote:
God dammit....
he won't help..... :roll:
Post Posted: Wed Mar 30, 2011 8:20 am
Cant hurt to ask :lol:
1989 WT Sierra.
Post Posted: Thu Mar 31, 2011 4:01 am
Hey guys another quick question about another one. The rear of a 88 WT? Would that be the same gearing to go straight in as a 89? Cheers!
1989 WT Sierra.
Post Posted: Thu Mar 31, 2011 4:43 am
Maybe. I would be checking the ratio your running and use the years a a guide. You never know if the donor has had the ratio swapped in a former life ;) (sorry i dont know year specifics)
Post Posted: Thu Mar 31, 2011 4:56 am
anything 88-89 treat as suspect, if it has metal flares it should be 3.7 like later ones, if it has plastic flares it could be either
Post Posted: Thu Mar 31, 2011 5:03 am
88 diff could be either 3.7 or 3.9 ratio, as that was the changeover year between NT and WT. Some of the new WT zooks were a bit of a hybrid.
You need to check the ratio of the diff centre you took out. Count the number of teeth on both the ring and pinion gears. Then divide the number of teeth on the ring gear by the number of teeth on the pinion gear.
For example (NOTE I'm not sure if these are the actual numbers, you need to count for yourself):
Ring = 41 teeth
Pinion = 11 teeth
41/11 = 3.7 ratio
Member of C.O.R 4x4
Post Posted: Thu Mar 31, 2011 5:36 am
Only reason im really double checking is because im using this to drive to work daily, so if i go ripping bits apart and fuck something i dont want out of transport :(
The donor car im looking at is zook95's tintop hes wrecking here.
http://www.auszookers.com/index.php?nam ... ic&t=18902
Looks to me very similar to mine as in flares and such. Except mine as metal and his are apparently plastic?
Anyway using the VIN numbers or anything to compare?
Post Posted: Thu Mar 31, 2011 5:58 am
That might mean the diff ratio's are different to yours. I wouldnt buy it before checking the ratio of your diff first.
Member of C.O.R 4x4
Post Posted: Thu Mar 31, 2011 6:15 am
Is there some info anywhere online that lists the different diff ratios for different models?
1989 WT Sierra.
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Thu Mar 31, 2011 7:35 am
You can find that info on here, but as royce said 88-89 can be a big unknown as there were 3 model changes those years.
They went from Nt-Wt in 88 and from sj50 to sj70 in 89.
Users browsing this forum: Google [Bot] and 61 guests
