It is currently Sat Oct 31, 2026 8:12 am
Post Posted: Wed Mar 30, 2011 7:45 am
havent had much luck redoing my cv's and when putting the the back bolts in one broke. should i get it drilled out or get another one
Post Posted: Wed Mar 30, 2011 7:46 am
have you tried an easy out?
Post Posted: Wed Mar 30, 2011 7:50 am
yeh i would try and easy out
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Wed Mar 30, 2011 7:52 am
ive never used one of them. are they easy to use
Post Posted: Wed Mar 30, 2011 7:53 am
do you own a welder?
Post Posted: Wed Mar 30, 2011 7:54 am
That'll come out by hand. It's not like it's siezed in there
yea they are pretty simple to use, but sometimes the bolt is in to tight and turning too hard can break the easy out. in that case you have to drill it out a little bigger ( as close as possible to the thread| and re-tap the thread
Post Posted: Wed Mar 30, 2011 7:58 am
drill a small pilot hole roughly the same size as your phillips head screwdriver socket bit (but a touch smaller) - hit the screwdriver bit into the hole with one hard whack, and unscrew it.
Post Posted: Wed Mar 30, 2011 8:00 am
no i dont have a welder.
ill get an easy out tomorrow and give that a go
thanks all
Post Posted: Wed Mar 30, 2011 8:05 am
try aliens idea before spending money on an easy out, you will have to drill a hole anyway
Post Posted: Wed Mar 30, 2011 8:07 am
how much is an easy out ?
Vehicle: 1985 Holden Drover
Post Posted: Wed Mar 30, 2011 8:08 am
Youd pick up a decent set for pretty cheap (dont know exactly) but they are very useful to have!
1989 WT Sierra.
Post Posted: Wed Mar 30, 2011 8:14 am
easy out's blow, if you snap it in there you can't drill it, cause it's tool steel..
center punch the center of the busted bit, run a small drill down the gut's & increase drill bit size till you can pick out what's left of the bolt, if your lucky it will start turning with the drill, then just un screw it..
Post Posted: Wed Mar 30, 2011 8:15 am
I think I got a cheap set from super cheap for about $12 I think
Post Posted: Wed Mar 30, 2011 8:19 am
What Alien and Stekky said, should come out easy as it shouldn't have bottomed out in there.
Post Posted: Wed Mar 30, 2011 8:22 am
rough bastard :helloo:
Post Posted: Wed Mar 30, 2011 8:31 am
See what happens when you paint things red that should be black?
Should come out easy enough.
Post Posted: Wed Mar 30, 2011 8:33 am
i havent had much luck with this rebuild im over it atm and i havent done one side yet the first thing i did was i put the king pin bearing up side down so had to get the grinder out. and now this happens
Post Posted: Wed Mar 30, 2011 8:35 am
the benefit of these sets is that if it does snap you CAN drill it out, they are soft as shit and completely useless.
a decent set (ie. sutton) will cost you $45 - $50.
Post Posted: Wed Mar 30, 2011 8:39 am
thats the way I'd go. at worst you end up redrilling the same size and you need to hellicoil or re-tap it.. snap off an easy out and your in a whole new world of pain
Users browsing this forum: No registered users and 474 guests
