It is currently Thu Oct 29, 2026 6:58 pm
Vehicle: Suzuki LJ50 & LJ81
Post Posted: Wed Apr 06, 2011 12:29 am
Anyone got a Jimny front diff center they can measure? I need to know the ID (Internal Diameter) of the crown wheel. Both 8 and 10 bolt crown wheels would be great. I want to use the hemisphere in an LJ if I can make it fit.
Fity
Post Posted: Wed Apr 06, 2011 12:44 am
I have 1 jimny front centre to get rid of here..
Crownwheel ID 107mmish, By verniers by eye as i cant get them in there.
4.09 High pinion(reverse cut gears), like all jimny fronts. The centre bolts up with 8 bolts, And the crownwheel bolts to the carrier with 8 bolts.
Jimny rears are low pinion, very similar to 1.3 sierra in sizing. So thats the 10bolt your talking about.
Post Posted: Wed Apr 06, 2011 1:01 am
Thanks BlueSuzy. Can you also give me the overall length between the shoulders which the bearing press up against. I need to use an LJ crown wheel and pinion in an LJ housing.
Post 2003 Jimny fronts have a 10bolt crown wheel. 98 to 03 have a 8 bolt front. I need to use an LJ crown wheel and pinion, might be a chance of fitting a RD118. :D
I'd be interested to see if a 10bolt has the same ID, it would save re drilling the crown wheel mounting face if the LJ crown wheel fits over the hemisphere.
Post Posted: Wed Apr 06, 2011 1:17 am
crownwheel carrier, inside shoulders for bearings. 93mm
Full length of carrier is 133ish, edges of the tube which bearings go around.
Mine is out of a 00'm13aauto.
What are the Lj dimensions?
Post Posted: Wed Apr 06, 2011 1:32 am
Thanks again.
I have the LJ center at home and I can't remember exactly what the spces are but I am guessing smaller.
Post Posted: Sun Apr 10, 2011 11:41 pm
The LJ is 97mmish (couldn't get the verniers in and it was to late for the rattle gun) 90mmish between bearing shoulders.
Can you tell me the PCD of the 8 crown wheel bolts? There is plenty of crown wheel that can be machined off (machining case hardened gears is fun) to fit the larger hemisphere and I hope the bolts will be the right PCD.
Users browsing this forum: No registered users and 114 guests
