It is currently Wed Oct 21, 2026 10:42 am
Post Posted: Tue Apr 12, 2011 3:19 am
ok well its almost winter and i was driving home other night and theres a bit of rain and noticed how stupidly slow my window wipers are ..but are all zooks stupidly slow when it comes to this is there a fix ?
Post Posted: Tue Apr 12, 2011 3:58 am
Don't know if its across the board, but mine are! Usually a clean and lube of the linkages will do wonders in a older car.
As the internal cage makes getting to motor and assembly hard, I haven't bothered. Instead I use rain-x on the outside and fog-x on the inside, that sorts it out for me.
Post Posted: Tue Apr 12, 2011 4:29 am
Yeah, as Tim said. If you drop the screen down (soft tops only) you can strip apart all the linkages and grease up the sockets. Also spray a bit of WD40 or similar on the moving parts that go through the panel under the screen. These tend to sieze up a bit.
Post Posted: Tue Apr 12, 2011 4:31 am
so basicly Fold down window and flood with WD40 ? :D
Post Posted: Tue Apr 12, 2011 4:33 am
hey i had a look at the Rain X thing do they work well ?
Post Posted: Tue Apr 12, 2011 4:53 am
rain-x is awesome, the water beads up making it easier to see through. Then once over about 60kph the water runs off. Most of the time I don't use wipers in rain - especially at night on the highway, the wipers are a distraction and do nothing of benefit anyway.
I use it on windscreen of all my cars, motorbike goggles & waterproof camera housing.
Fog-x is also good, as I find the demister a bit hit and miss.
Post Posted: Tue Apr 12, 2011 4:57 am
and places i can buy this from ..
Post Posted: Tue Apr 12, 2011 5:02 am
Just search rain-x on Ebay
Post Posted: Tue Apr 12, 2011 5:04 am
Just about any autostore should stock it. They usually sell a single wipe or a bottle that'll last you a couple of yrs for nearly the same price :crazy: Don't buy the single wipe!
Application as per the bottle. I do all side/rear windows and mirrors too.
Post Posted: Tue Apr 12, 2011 1:20 pm
The problem I have with Rain-X is the need for constant reapplication.
Users browsing this forum: No registered users and 156 guests
