It is currently Tue Jul 28, 2026 11:35 am
Post Posted: Sat Apr 16, 2011 6:33 am
Can some of you manly sophisticated vitara owners open your bonnet (yes I know doesnt need to happen very often) and get some pics of your engine bay for me?
especially around the battery for areas a little 4 fuse fuse holder and some relays might be able to be mounted
ill need all the variations, carby, efi, later models, 2 litre etc so theres some fun for everybody :lol:
ta :helloo:
Post Posted: Sat Apr 16, 2011 6:49 am
Do ya want pics of mine? its the same as your's :lol:
Post Posted: Sat Apr 16, 2011 6:50 am
yeah cause mines got teh starter battery on the drivers side and aux battery on the pass side and I cant remember how it used to be :)
Vehicle: 75 Cruiser
Post Posted: Sat Apr 16, 2011 6:59 am
x90
Post Posted: Sat Apr 16, 2011 7:10 am
Mine 96 swb EFI
Kate's 92 lwb EFI
Let us know if ya need better pics
Post Posted: Sat Apr 16, 2011 7:11 am
SV420
Post Posted: Sat Apr 16, 2011 8:04 am
:goodjob:
they dont make life easy :(
Joe, your wiring is terrible!
Vehicle: LWB Sierra & XL7
Post Posted: Sat Apr 16, 2011 8:05 am
Hey Joe, It's probably unlikely, but are the battery tray's removable?
They're probably spot welded in, but I presume they can be fitted to earlier models.
'92 Vitara & Camper trailer
Post Posted: Sat Apr 16, 2011 8:15 am
the later tray over that side is welded in
the early tray on the drivers side bolts in, but doesnt fit the later ones cause its a different booster :(
Post Posted: Sat Apr 16, 2011 9:12 am
SV420
sv620 looks to the same as sv420
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Sat Apr 16, 2011 9:23 am
G16a. Crappy phone pics, Hope they help.
Post Posted: Sat Apr 16, 2011 9:34 am
Do people reckon down beside the battery is an ok place to stick a fuse panel and relays?
Post Posted: Sat Apr 16, 2011 9:39 am
sealed? cos itll get wet...
Post Posted: Sat Apr 16, 2011 9:40 am
yep. nice and cool and about 1.75 inches of space.
Post Posted: Sat Apr 16, 2011 9:42 am
how?
if you have enough water that high up to worry that sort of shit then its the least of your current problems
Post Posted: Sat Apr 16, 2011 9:43 am
It's about the only place I haven't got mud. :D
Post Posted: Sat Apr 16, 2011 9:46 am
how?
had my fuse box underwater last year, had to hose it out again when i got home just in case the water was salty. nothing went wrong but yeah, in hindsight i'd like the fusebox more against the firewall behind the battery.
Post Posted: Sat Apr 16, 2011 9:51 am
cant do on a vitara
sealed or not (all are not cause nobody here could afford a truly sealed fuse box) if electrics go underwater they should all be cleaned and maybe a bit of crc sprayed around anyway cause youll get corrosion on pins and so on
Post Posted: Sat Apr 16, 2011 12:32 pm
sv625
Go Hard, Trailer Home
Post Posted: Sat Apr 16, 2011 3:56 pm
I've screwed a 6-fuse block to the firewall directly behind the battery of my 93 LWB - right between that useless black plate and the two ID plates:
Just unclip the loom and push it out of the way.
...and you thought Joe's wiring was dodgy! :oops: It's not like that anymore...
Post Posted: Sat Apr 16, 2011 6:13 pm
:goodjob:
:blink: Are you talking bout the wires going to the battery :? :oops:
How do i fix it or how should it be wired? :oops:
I hate playing with wires and stuff :evil:
I'm pretty drunk atm :thefinger:
Post Posted: Sat Apr 16, 2011 8:59 pm
Joe wrote:
:goodjob:
them skinny wires, what are they? besides a fire waiting to happen?
the compressor power wire you could turn around so its at least poking out of the terminal the same way as teh rest
the fuse for the doof doof should be screwed to something, see if you can get a long chunk of cable and a terminal and screw it to teh firewall
Post Posted: Sat Apr 16, 2011 9:59 pm
Do the earlier vits have a left and right hand headlight fuse under the bonnet?
Post Posted: Sun Apr 17, 2011 2:30 am
Joe wrote:
:goodjob:
:oops:
Skinny wires are the uhf
Ill play around with the other wires later when i'm a bit less hung over :blink:
Post Posted: Sun Apr 17, 2011 2:40 am
hook the uhf up behind the stereo, either use off the cig lighter if you want it to turn off with the key or the radio memory wire if you want it on all the time
Just had a play with mine, on high beam it drops .5v on the power side and 1v on the earth side, which is quite bad
Post Posted: Sun Apr 17, 2011 2:47 am
:blink: That's a good idea ill do that so i can turn it off at the key :D
Why is yours dropping volts?
Post Posted: Sun Apr 17, 2011 3:00 am
they will all be dropping volts, too thin wire and shitty switches
got a multimeter? you can check yours out too (as could everyone else)
Post Posted: Sun Apr 17, 2011 3:11 am
Nope but Tasbrad does, ill go over there and annoy him soon :D
Post Posted: Sun Apr 17, 2011 3:21 am
ok, if you set the meter to volts, stick one end on the battery positve and the other end on teh drivers headlight terminal marked ground, with engine idling and high beam on, the reading is how much you are losing on the positive side
then move the meter to the opposite vertical terminal on the plug and the other probe to battery negative youll see how much it drops on the switching side
in a perfect world you wouldnt want to lose more than .5v total
Users browsing this forum: No registered users and 408 guests
