It is currently Tue Jul 28, 2026 11:36 am
Post Posted: Mon Apr 18, 2011 5:59 am
Got a wide track 1.3 sierra. Have detirmined not worth working this motor being carbi job poor results with turbo. Vitara 1.6 seems common choice in injected form with adjustable computer for turbo. Is running gear strong enough or will I have to change everything?
Post Posted: Mon Apr 18, 2011 6:08 am
better of with a built 1.3 than a 1.6, most of the guys on www.redlinegti.com run 1.3 with 1.6 pistons or forged items
most useful info related to your questions is on there
Post Posted: Mon Apr 18, 2011 6:15 am
I think a turbo GTI would be more reiable than a turbo G16B.
Post Posted: Mon Apr 18, 2011 6:23 am
Save me searching, which I am hopeless at, can you link to a build, I had a look at the site, crikey, no idea where to start.
Vehicle: 95 Sierra Soft top
Post Posted: Mon Apr 18, 2011 6:43 am
They only run vitara pistons cause the lower comp then the gti ones, better for the turbo,
Had a mate did 12.8 down the 1/4 withe just a base turbo kit vitara piston and a heltec computer, not bad for the 1.3
Post Posted: Mon Apr 18, 2011 6:51 am
Don't they run B16 honda pistons? Or is that to raise comp.? :?
Vehicle: LJ20 LJ50
Post Posted: Mon Apr 18, 2011 8:13 am
no to drop compresiion
Camels have nice toes
Vehicle: '96 LWB trayback
Post Posted: Mon Apr 18, 2011 8:30 am
The honda pistons are more common and cheaper in forged form as they have a bigger aftermarket presence.
They are available in a wider range of compression ratio's, to both raise and lower static compression. The same amount of options aren't available in suzuki parts.
Post Posted: Mon Apr 18, 2011 9:56 am
not sure these days, its been about 3years since my last gti lol, and back then it was vitara pistons that was in,
But I did use honda civic valves for my head, cause thry where .5mm bigger then gti ones
Users browsing this forum: Google [Bot] and 419 guests
