It is currently Tue Jul 28, 2026 7:18 pm
Post Posted: Mon Apr 18, 2011 1:44 am
Hey fellas,
I got a 1992 LWB Vitara with about 280kkm on it, and the auto is getting abit clunky. Reverse takes 1/4 throttle to kick in, and shifting is pretty violent sometimes.
Also when driving along a flat with no throttle, sometimes it shifts up and down, up and down at 2 second intervals, like it cant decide what gear to be in.
Is my auto box on the way out or does it just need a fluid change? I hear the autos are hard to find for LWB Vitara so maybe a manual conversion would be a goer, if not too difficult?
Post Posted: Mon Apr 18, 2011 2:15 am
Are you leaking fluid? When I used to drive my dads ancient merc it leaked auto fluid a lot and when I topped up the fluid it would shift a lot smoother. When it was low on fluid gear changes took ages and were harsh.
In your case I would start with a fluid change. Maybe even the filter/screen as well.
You get also gets the bands tightened.
2002 SWB GV
Lifted and Locked
Post Posted: Mon Apr 18, 2011 8:14 am
TheOtherLeft's comments should see to it.
The AW-4 is a durable auto and very conservatively rated in a vitara. It shouldn't be broken.
Post Posted: Mon Apr 18, 2011 9:28 am
how long since it has been serviced
Post Posted: Mon Apr 18, 2011 9:31 am
how long since it has been serviced the more it changes gear the hotter it gets the heat breaks the fluid down
what color is the fluid
Post Posted: Mon Apr 18, 2011 10:06 am
thanks fellas
levels are normal, color is a dark yellow, but hard to say on the dipstick.
no idea when it was last serviced, the motor was replaced recently by previous owner but no clue on the auto, i suspect its the original.
Post Posted: Mon Apr 18, 2011 11:48 am
I changed my trans fluid a few weeks ago. The colour of fluid on the dipstick was darkish red. When I dropped the fluid from the pan it was actually black so definitely past it's service date. It had done about 135,000km.
2002 SWB GV
Lifted and Locked
Post Posted: Mon Apr 18, 2011 11:55 am
Dark yellow?
Shouldn't DXII be red?
Vehicle: 4wd
Post Posted: Mon Apr 18, 2011 11:58 am
Yep Dexron is red. Makes chrome spanners look like new :)
Watch out or you'll get sued.
Post Posted: Mon Apr 18, 2011 9:40 pm
For reference Synthetic trans fluid is green (well the Castrol one is)
2002 SWB GV
Lifted and Locked
Users browsing this forum: No registered users and 532 guests
