It is currently Wed Sep 30, 2026 1:40 pm
Post Posted: Fri Apr 22, 2011 11:12 am
What driveshaft is everyone using after they have done a Lux diff conversion ? I will be using square shafts but need to know whether I can reuse my old Sierra yokes and unis of whether I will need to source some Lux ones ? Will the Sierra unis hold up to 38's ?
According to this post...
tanshi wrote:
the wide track sierra and the lux are the same bolt pattern as im using lux tail shafts on my LJ there is a little bit of griding to make the two fit up but they will go.
The Lux shafts are a straight fit for the LJ's is this the same for the SJ's ? Also what grinding was needed ?
Post Posted: Fri Apr 22, 2011 11:17 am
I would run with the lux uni's as they seem to be alot stronger eg.mattzook hasn't busted a hilux uni yet and you know how hard he is on gear and yet I have blown a sierra uni only running 32's and a 1.3
Post Posted: Fri Apr 22, 2011 11:32 am
Go the lux shafts. I have a lux shaft on the ute. The flange PCD is the same, but the locating spigot is 1mm too big in diameter. The remedy for this is to get the locating recess on your pinion and transfer flanges bored +1mm.
I also had the shaft lengthened to suit.
Post Posted: Fri Apr 22, 2011 11:46 am
Cheers guys
Post Posted: Fri Apr 22, 2011 10:45 pm
80 series shafts are ment to bolt up also....
http://auszookers.com/index.php?name=Fo ... ght=series
Users browsing this forum: No registered users and 140 guests
