It is currently Thu Nov 05, 2026 1:50 pm
Vehicle: 1987 sierra tray back buggy
Post Posted: Fri Apr 29, 2011 2:15 pm
So basically at any sort of speed the car is floating from one side of the track to the other even on flat surfaces. and requires a large amount of working the steering wheel to keep it in a straight line.
there is quite a lift in this rig and some intresting fab work but im trying to diagnose where to look for this problem i cant really understand what may be the cause of this problem as it isnt a constant one direction thing.
Post Posted: Fri Apr 29, 2011 2:37 pm
pics of set up?
Post Posted: Fri Apr 29, 2011 3:02 pm
check the steering box for play, adjust accordingly. Do not over tighten, other wise it will bind at fll lock, and wear faster.
Vehicle: Clown Car..
Post Posted: Fri Apr 29, 2011 3:38 pm
i reckon skyman is on the ticket with the Steering box..Iv got at least 1/2 a turn either way before the front wheels even think about goin left or right, gets a tight spot before full lock, but Im suspecting iv got a colapsed bearing in mine, Got a replacement to go in tomorrow. :D
Quick Question while we are discussing steering boxes.. Oil or Grease? quantity? viscosity? some have said to use grease, others oil, others Moreys..
So... Whats the suggestions from the forum!?
Post Posted: Fri Apr 29, 2011 3:49 pm
I think here we use the same gear oil we do in the gear box, bit don't quote me. You can pull the lid and find out, but I am sure it is a liquid oil of some type.
Post Posted: Fri Apr 29, 2011 8:35 pm
I'm banking on caster if it's a solid front end.
Vehicle: 75 Cruiser
Post Posted: Fri Apr 29, 2011 8:51 pm
Is this your red comp truck? I wouldn't go fast in that! :lol: ... your front diff is probably drifting left to right!
Post Posted: Fri Apr 29, 2011 9:32 pm
Molly grease or graphite grease does the trick very nicely...
Vehicle: '94 suzuki maruti
Post Posted: Fri Apr 29, 2011 10:18 pm
mine used to do this really bad, and it was my wheel bearings. they're a simple check, worth checking and ruling them out early.
Post Posted: Fri Apr 29, 2011 10:23 pm
give it some toe out, its easy, free and will work
Post Posted: Fri Apr 29, 2011 10:42 pm
first thing i thought when he said "big lift".
Post Posted: Fri Apr 29, 2011 11:12 pm
Big lift =18" worth of lift
Yes it's on the red thing
Post Posted: Fri Apr 29, 2011 11:22 pm
with a list of suspension and steering mods as long as yours
id say you have a long process of elimination before u get it sorted
it may be a combination of a whole lot of stuff :wink:
Post Posted: Fri Apr 29, 2011 11:48 pm
X2 did you use new bushes in the front springs, and tightened up all the bolts under there ?
Post Posted: Sat Apr 30, 2011 3:45 am
thanks guys for the quick straight forward advice.
-for pics check the life and times of james thread in the rigs section, there are too many to repost.
-The wheel bearings were new but i will check and eliminate or confirm that
- suspension bushes were new
-toe out obviously this tries to pull the diff apart thus keeping it in a straight line?
- steering box is probably the problem as it is a random box out of some old road car that i got cheap. (having thought about this)
-do you think that going hydro would be the quickest and easiest way to eliminate all the working out of angles and so forth in the steering?
-However the angle on the draglink isnt that steep anymore.
thanks for the advice guys
Post Posted: Sat Apr 30, 2011 4:06 am
SR= castor problems.
Post Posted: Sat Apr 30, 2011 4:08 am
SR?
Post Posted: Sat Apr 30, 2011 4:15 am
Shackle reversal.
Post Posted: Sat Apr 30, 2011 4:24 am
Ah k
i will check the castor again. i thought it was set to about standard as i had to change the spring perches so i rotated them slightly to bring the diff to the same position in terms of the castor after the suspension change as before.
Post Posted: Sat Apr 30, 2011 4:28 am
did you check it when fitted to the car? The springs compressing under the weight f the vehicle can change the diff angle slightly. It is hard to set that up sometimes.
Post Posted: Sat Apr 30, 2011 4:39 am
yeah checked and changed once it was fitted. I machined up a couple of correction plates and put them in so it was at a point that i thought it was right but it could still be not right.
Post Posted: Sat Apr 30, 2011 4:45 am
Did the plates make it better or worse to drive?
Post Posted: Sat Apr 30, 2011 4:51 am
they reduced the side to side lean when the car was turned ie turn left and the drivers side lifts up and visa versa. zzbut after measuring it i thought there was still +3 degrees of castor angle
however never had a real chance to drive it at speed before i put in the plates.
Post Posted: Sat Apr 30, 2011 5:58 am
not so much toe out makes it more stable but less toe in makes it less jittery, toe in the outside edge of the tyre picks up on surface changes so it darts around a bit, too much toe out will make it do stupid things as well though
lol at you lot and castor, my mini (therefore better handling and more responsive to suspension changes than anything here) barely changes with up to 3 degree of castor change compared to huge differences in the slightest toe or camber change, I really wish this internet rumour would die
Post Posted: Sat Apr 30, 2011 7:27 am
But Royce! Extended shackles are akin to satin! They put the castor out and make sierras do cart wheels down the highway! Surely the rumours are true? :roll:
Post Posted: Sat Apr 30, 2011 8:11 am
its not the castor is the problem with fangs, its the leverage on the bushes and springs, if you stiffened up the bushes and probably even the spring so it somehow cant twist as easy so the same sideways load caused the same deflection I doubt you would notice they were there
Post Posted: Sat Apr 30, 2011 8:12 am
Yeah maybe. Kind of defeats the purpose of longer springs and shackles though. Guess you can't have on road manners and flexy leaves :roll:
Another vote for links and coilovers :lol:
Post Posted: Sat Apr 30, 2011 8:19 am
yeah whod of thought anything that might make the suspension move up and down easier might also let the body move side to side as well :)
Post Posted: Sat Apr 30, 2011 8:32 am
Shadup :lol: :helloo:
Post Posted: Sat Apr 30, 2011 8:38 am
stiffen it up a bit, flex aint everything - even on a comp rig
Users browsing this forum: Google [Bot] and 34 guests
