It is currently Fri Nov 13, 2026 12:19 pm
Post Posted: Sat Apr 30, 2011 11:01 pm
After multiple water crossings in my 1998 2.5 v6 grand vitara the air con compressor bearing sounds a bit dry and is very noisy. Has anyone had any dealings with changing a bearing/pulley? Is it expensive? Genuine or non genuine parts? Starting to annoy me as its getting louder and louder. :?
Post Posted: Sat Apr 30, 2011 11:40 pm
The cheapest way would be to get a pully second hand,,, They use the same compressor as BB Jimny and Type 3 Baleno. The compressors are farly common to fail now days so there should be a pully or 2 floating around somewhere.
Suzuki is my way of life.
Post Posted: Sat Apr 30, 2011 11:58 pm
10mm allan key, 10mm spanner & cir clip pliers, easy...
Post Posted: Sat Apr 30, 2011 11:59 pm
:roll: & a 12mm spanner.
Post Posted: Sun May 01, 2011 3:54 am
Thank you for the advice. So is it possible to replace the pulley whilst the A/C compressor is still in the car or will i have to remove it???
Post Posted: Sun May 01, 2011 5:59 am
I've done it, but i'm used to working with my hand's & arm's in stupid place's...
Pull your radiator out & you'll piss it in..
Users browsing this forum: No registered users and 67 guests
