It is currently Tue Oct 27, 2026 5:41 am
Post Posted: Sun May 01, 2011 4:47 am
ITEM:
1: Front custom tube bar to suit Sierra with 9500lb Ironman winch
2: Rear custom bar with swingaway tyre carrier plus built in airtank=
PRICE AND PRICE CONDITIONS:
1: $800
2: $800
CONDITION:
1: Good condition, winch works perfect
2: Good condition, needs a paint
REASON FOR SELLING:
Stripping sierra, getting mortagage
EXTRA INFO:
1: Front bar is a custom tube bar made by me. The centre winch carrier is from a chopped down Ironman winch bar which I plated and made tube outriggers. Whole bar is coated in two coats of POR15 Rustpaint and one coat of POR15 black. The mounts are made to suit my custom RUF conversion and will need some modification to fit a standard sierra. For a start a 2" bodylift is needed unless you want to start cutting into front clip. Comes with winch control box and wireless controller, hook, fairlead, etc everything you see in pictures.
2: Rear bar is also custom made by me out of SHS bar which I completely sealed to use as an airtank. Comes with barbs as you can see for air in and out. You could just block one hole off if you like and use the one hole. Swingaway carrier uses Holden stub axle so is strong as houses. Has a latch to stop it swinging closed when open on side angles, also has mounts for number plates and comes with a numberplate light. When mounted to my sierra it mounted a 31" simex on rim nicely. You could fit much larger tyres on it but numberplate would start to be obscured. Has hinges welded to the front of the bar on the sides to mount mudflaps too. Bar is made for 2" bodylift but could fit without bodylift with some angle grinder massaging on your sheetmetal. It uses the four lower bolts and two body mount bolts to mount. I drilled out the four lower captive nuts and welded in larger nuts to use larger bolts, but that is optional. I didnt have a chance to paint this in POR15 so it only has primer and black rattlecan coat, has a little surface rust bout would come up mint with a nice sprayjob.
Glen Waverley
CONTACT:
0438858325
PICTURES:
Post Posted: Sun May 01, 2011 4:49 am
Post Posted: Sun May 01, 2011 5:07 am
Bit rich on the rear bar mate but good luck with your sale. Air tank in the rear bar is a friggin good idea.
Conrad
I HATE CYCLISTS!!!
Post Posted: Sun May 01, 2011 6:12 am
Conrad
Couldnt get it made for less than that - Ive built my share of rear bars and one with a swingaway is time consuming and even more so making sure that your welds are up to scratch using the rear bar as an air tank.
Good prices there btw.
Post Posted: Sun May 01, 2011 6:16 am
daisy wrote:
Conrad
X2.
Id tell you to GFY if you asked me to make that for less than $1500. Lots of hours in something like that.
GL with sale.
Vehicle: WR250F/Jeep XJ
Post Posted: Sun May 01, 2011 9:47 am
Solid work and a good price. Try and get someone to make one for that price. It's the tight ass zook owner in all of us. Put it on eBay PJ. someone will snap it up.
Post Posted: Sun May 01, 2011 9:54 am
Lol yeh we are all tightasses, thats why im separating the zook. Noone wants to pay many thousands of dollars for a zook, but then end up doing it anyway with separate parts.
Post Posted: Sun May 01, 2011 10:01 am
Just curious but would you separate the bar and winch?
Post Posted: Sun May 01, 2011 10:45 am
If noone wants to buy them both, then I will consider separating.
Post Posted: Sun May 01, 2011 11:58 am
Any chance you could modify that front bar to mount onto a SWB vit?
Post Posted: Sun May 01, 2011 9:01 pm
Hi PJ,
Has the rear bar got provisions for a tow bar? thanks...
Post Posted: Sun May 01, 2011 9:06 pm
Dont remember what the mounts look like, but with enough skill you could mount anything to anything.
rpmwrx wrote:
Hi PJ,
I was going to fit one by either welding a receiver to the bottom of the SHS, or cut a slot out of the SHS and weld the receiver up inside. Never got around to measuring heights etc... I even have a length of SHS I bought to use as the receiver that I can cut for ya.
Post Posted: Mon May 02, 2011 3:38 am
How much would you be lookin at for just the bar
Vehicle: LWB Sierra
Post Posted: Mon May 02, 2011 4:28 am
Hi PJ,
If i can get rid of my front bar i will buy yours!
Where did you put the front indicators?
Cheers,
Andrew
Post Posted: Mon May 02, 2011 6:45 am
nice rear bar mate good idea GL with the sale
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Mon May 02, 2011 7:13 am
anDy86 wrote:
Hi PJ,
Cheers,
Andrew
I fitted indicators beside the headlights.
Post Posted: Mon May 02, 2011 7:41 am
tough zook mate, looks the goods
Post Posted: Mon May 02, 2011 9:40 am
Man thats cheap for a front bar with a winch included. I sold my bar for $500 on its own and then the farked winch for another $250.
I can tell you all the rear bar is extremely strong. Seen PJ reverse into trees with it and the trees always come off 2nd best. :roll:
Post Posted: Thu Jun 02, 2011 9:32 am
If that bar is still available i will take it depending on postage costs to WA
PM Me sort something out
Post Posted: Wed Jun 08, 2011 6:07 am
Alright I'm sick of being buggered around, will sell both bars (no winch) for $1000 and can deliver almost any major city in Aus for less than $100.
Post Posted: Wed Jun 08, 2011 8:47 pm
Did the rear bar come off a w/t?
swb sierra, bundera diffs, spoa on yj leaves, 35's
Post Posted: Wed Jun 08, 2011 9:10 pm
Yes it did
Post Posted: Wed Jun 08, 2011 9:14 pm
Post Posted: Fri Mar 30, 2012 5:55 am
Well pretty much everything else is gone, forgot to advertise the winch bar again.
$600 for the winchbar, can deliver for free if you are within reasonable distance of Dandenong.
Post Posted: Fri Mar 30, 2012 4:17 pm
rpmwrx wrote:
Hi PJ,
lol why do you want a rear ross lol
Vehicle: SUZZI
Post Posted: Fri Mar 30, 2012 6:19 pm
hey mate have you still got the front bar and winch? im keen on it but how much would be postage to qld 4555?
thanks heaps
trite
lux diffs,twin locked,crawler gears,37s,etc
Post Posted: Fri Mar 30, 2012 7:45 pm
Postage would be around $50 from depot to depot. If you want the winch I can include it but it wouldn't be stupid cheap as it works perfectly good and I would need to replace it for my current fourby.
Post Posted: Mon Apr 02, 2012 5:36 pm
front bar still 4 sale?? got pics??
Post Posted: Wed Apr 04, 2012 6:35 am
Still for sale-ish. A couple of people are still umming and ahhing. Whomever gets me the cash first gets it.
Will get more pics tonight.
Users browsing this forum: No registered users and 59 guests
