| Author |
Message |
shane1992
Joined: Tue Jun 08, 2010 10:09 am Posts: 782 Location: Wollongong
 Posted: Tue May 03, 2011 5:34 am |
How hard and risky is it doing this yourself?
Ive gotten quotes from engine reco places from $80 to $140 for it...
But I know its possible to buy the hone tool and do it yourself...
This is my first engine rebuild, Ive got mates helping me, but none of them have actualy honed a cylinder before.. I know you have to get the right angle etc when doing it....
Should I just go ahead and let the pros that do it every day do it?
cheers,
Shane
shakes
Joined: Sat Apr 10, 2010 11:30 pm Posts: 4895 Location: Northcote
 Posted: Tue May 03, 2011 5:45 am |
The tool is close to that money. If your confident with your skills buy it. If your unsure you will end up spending alot more
We have used a cheap drill fitting to hone the bores of a couple of cheapo rebuilds. Worked ok. but they were definately budget rebuilds.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Tue May 03, 2011 5:48 am |
$80 to $140 for just a hone....
I rebuilt a 1.0 motor a while ago and 40 thou bore AND hone only cost $120.
If you have never done it before I'd suggest you at least watch someone do it before you attempt to... Get it wrong and your new engine will glaze bores and use lots of oil....
royce
how have you determined your bore and pistons are alright to go with jsut a hone?
vl2dy4
Joined: Wed Feb 16, 2011 8:40 am Posts: 424 Location: Australind WA
 Posted: Tue May 03, 2011 6:01 am |
Mate i rebuilt a LS1 Gen 3 poo box, i ordered a FLEXI HONE from enginehones.com they were about 1/4 of the price than purchasing from Australia.
Flexihones last for years and they give a better finish than the springloaded 3 stoned hone, also they are a shit load easier to use.
you just need to know the bore size and match a flexi hone that is just a little bigger.
I can tell you now that for a 4" hone it cost me under $80 delivered from the states.
Conrad
_________________ I HATE CYCLISTS!!!
shane1992
 Posted: Tue May 03, 2011 6:14 am |
royce wrote: how have you determined your bore and pistons are alright to go with jsut a hone?
Thats another point... Im also considering just getting oversized pistons and rings and boreing it out.....
Does anybody have a an idea how much that costs? And is there anything else I have to change besides getting larger pistions and rings...
If I just get the hone job, Ill pay soemone to do it I think...
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5944 Location: Northcliffe, W.A.
 Posted: Tue May 03, 2011 6:23 am |
Buy a hone (mount in drill style) and grab a few lawn mowers (not 2 strokes!) or even better, an old car engine from the tip and practice. Only give your engine a light hone though, if it still has cross hatching I wouldn't bother.
It's pretty hard to fuck it up.  The stones can be pretty fragile though.
Fatzook
 Posted: Tue May 03, 2011 6:53 am |
I've always used a bead hone. Looks like a toilet brush with heaps of lead balls on the ends of the 'bristles'. Just cycle it up and down through the bore in a battery drill on a slow speed.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Tue May 03, 2011 7:19 am |
I've only ever know of bead hones until I saw a rock one at super cheap the other day.
_________________ mlm
Fatzook
 Posted: Tue May 03, 2011 7:24 am |
SierraDan wrote: I've only ever know of bead hones until I saw a rock one at super cheap the other day.
Yeah you won't find many of those in pro engine shops.......
want33s
 Posted: Tue May 03, 2011 8:09 am |
Fatzook wrote: I've always used a bead hone. Looks like a toilet brush with heaps of lead balls on the ends of the 'bristles'. Just cycle it up and down through the bore in a battery drill on a slow speed.
Lead (Pb) Pete??? I don't think so Tim....
JrZook
 Posted: Tue May 03, 2011 8:13 am |
Lol id love to see your hone job after using one of these
There's usually made of Silicon Carbide SiC (stuff I play with at uni) or Aluminium oxide (much the same as a knife sharpening stone)
_________________ Lil Foot!
Fatzook
 Posted: Tue May 03, 2011 8:19 am |
sorry. I knew it was something soft.
rick1970
Joined: Sun Jul 04, 2010 9:39 pm Posts: 303 Location: Dungowan
As others have said, a ball hone is much easier to use. Most pro engine builders will 'finish' hone a fresh bore by hand with these, after a machine hone with 'Sunnen' type machine.
Ball hones are expensive, better to pay someone to do it if you won't use the hone again.
And it is easy to stuff up, expecially with a cheap 3 leg stone hone and no experiance.
royce
 Posted: Tue May 03, 2011 8:21 am |
um its not soft, its an abrasive
all you lot going yeah its easy bang it in a drill and off you go? you realise there is real specific angles, depths and overall material removal rates you need to adhere to dont you?
I guess it helps explain why so many people 'rebuild' engines that then proceed to still be shit or last a year before shitting themselves
mattybish
Joined: Sat Apr 16, 2011 5:14 am Posts: 74 Location: tassie
 Posted: Tue May 03, 2011 8:29 am |
honing is a real art form, it is best to spend the money and get it done by a person who does it all the time, it takes an awful lot of practice to get the correct angles and material removal rates, not to mention lubrication rates etc, i have done a 4 year apprenticeship and am only just getting to the stage where i am really happy with the quality of my honing, however getting practice on cheap, non important items such as lawnmovers etc is the best way to learn
steak_knife
 Posted: Tue May 03, 2011 8:36 am |
mattybish wrote: honing is a real art form, it is best to spend the money and get it done by a person who does it all the time, it takes an awful lot of practice to get the correct angles and material removal rates, not to mention lubrication rates etc, i have done a 4 year apprenticeship and am only just getting to the stage where i am really happy with the quality of my honing, however getting practice on cheap, non important items such as lawnmovers etc is the best way to learn
 Pfftttt!!!
327 chev was the first one i did.
i do agree with you tho...
& the 3 stone one's blow
Moph
Joined: Sat May 19, 2007 11:30 pm Posts: 2535 Location: Perth
Vehicle: 93 Sierra
 Posted: Tue May 03, 2011 8:40 am |
royce wrote: I guess it helps explain why so many people 'rebuild' engines that then proceed to still be shit or last a year before shitting themselves
I found that with my engine. I had a number of people on Outers say in my rebuild thread that rebuilt 1.3's often didn't make it past 20,000 kays. I had all the recon work done by a reputable engine builder and just did the teardown/rebuild myself with lots of new bits, quality oils etc. Has about 30,000km on it since then and purrs like a kitten.
mondo
Joined: Wed Dec 29, 2010 10:18 pm Posts: 481 Location: Jimboomba
 Posted: Tue May 03, 2011 8:41 am |
just make sure you get the engine bored out before you buy any pistons or rings for it
royce
 Posted: Tue May 03, 2011 8:44 am |
mondo wrote: just make sure you get the engine bored out before you buy any pistons or rings for it
shit no!!!!!
ask the engine guy how far it needs to be bored to be into good metal, buy the pistons to suit then get each cylinder bored to suit that piston
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Tue May 03, 2011 8:55 am |
steak_knife wrote: mattybish wrote: honing is a real art form, it is best to spend the money and get it done by a person who does it all the time, it takes an awful lot of practice to get the correct angles and material removal rates, not to mention lubrication rates etc, i have done a 4 year apprenticeship and am only just getting to the stage where i am really happy with the quality of my honing, however getting practice on cheap, non important items such as lawnmovers etc is the best way to learn  Pfftttt!!! 327 chev was the first one i did. i do agree with you tho... & the 3 stone one's blow
Like he said....cheap and not important
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Tue May 03, 2011 9:07 am |
personally I think if you want an engine worth a pinch of shit, you should just get the machining and sizing work done by a qualified engine builder at the very least.
MART
Joined: Thu Apr 26, 2007 11:30 pm Posts: 282 Location: Sydney
 Posted: Tue May 03, 2011 9:19 am |
For a non piston replacement with new rings a bottle brush honing tool to rough up the cylinder wall should only be used . The ridge does not have to be removed , those do it youself honing stones always taper the bore or make it more out of round. This information comes from a very professional engine reconditioner , not out my ass , it's cheap to get block's bored and cross hatched honed , my last one was $90. There a some jobs that should be left to the experts , not a butch of pissed cunts on a friday night , Rage on , Cheers Paul.
shane1992
 Posted: Wed May 04, 2011 12:06 am |
Yeah, I think im just gunna get the pros to do it, and get it bored out if needed then get bigger pistons....
Anyone wanna buy a set of standard 1.6L Pistons and rings for cheap?
ball
Joined: Wed Oct 22, 2008 10:30 pm Posts: 4673 Location: Katherine
 Posted: Sat May 07, 2011 11:34 am |
MART wrote: For a non piston replacement with new rings a bottle brush honing tool to rough up the cylinder wall should only be used . The ridge does not have to be removed , those do it youself honing stones always taper the bore or make it more out of round. This information comes from a very professional engine reconditioner , not out my ass , it's cheap to get block's bored and cross hatched honed , my last one was $90. There a some jobs that should be left to the experts , not a butch of pissed cunts on a friday night , Rage on , Cheers Paul.
Where has the cross hatch gone
billrogers
Joined: Mon Aug 16, 2010 11:03 pm Posts: 81 Location: Dubbo 2830 NSW
 Posted: Sat May 07, 2011 12:05 pm |
ball wrote: MART wrote: For a non piston replacement with new rings a bottle brush honing tool to rough up the cylinder wall should only be used . The ridge does not have to be removed , those do it youself honing stones always taper the bore or make it more out of round. This information comes from a very professional engine reconditioner , not out my ass , it's cheap to get block's bored and cross hatched honed , my last one was $90. There a some jobs that should be left to the experts , not a butch of pissed cunts on a friday night , Rage on , Cheers Paul.  Where has the cross hatch gone  A short lived oil burner in progress??
_________________ *JIMNY*
'99 G13BB, Auto, White.
skyman
Joined: Wed Nov 17, 2010 2:06 pm Posts: 1328 Location: Yakima, wa (us)
 Posted: Sat May 07, 2011 5:57 pm |
Quote: A short lived oil burner in progress??
I doubt we'd see one of those from Mart. He does top work.
