It is currently Sun Oct 04, 2026 7:27 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
lesspostingmorewheeling
Post Posted: Tue Aug 26, 2008 12:18 am
i was thinking just make one then make a matching one the right size
i'll have to do that when i work out the problem i've got with that plate thing the ubolts go through
Post Posted: Tue Aug 26, 2008 12:25 am
just re drill them the same as your spring pads for the spring bolt, then they bolt up.
Post Posted: Tue Aug 26, 2008 12:30 am
what do i have to redrill where? would you have a pic by any chance? i was looking at it the othere day and couldn't work out what to do
Post Posted: Tue Aug 26, 2008 10:09 pm
only do this if you have redrilled your spring pads. if you re drilled your rear spring mount you don't need to do it.
it just re drilled the same as the spring pad on the diff and your done
Users browsing this forum: No registered users and 198 guests
