It is currently Mon Oct 19, 2026 9:17 pm
Post Posted: Fri May 06, 2011 8:22 am
hi i need a new drivers side seat or both as both of mine are broken
for a 1994 sierra
cheers Brad
Post Posted: Fri May 06, 2011 9:35 am
look for some swift GTI seats.. theyre more bucketed and comfy.
check http://perth.gumtree.com.au
Post Posted: Fri May 06, 2011 9:36 am
hah look at that - someones selling some in perth: http://www.auszookers.com/index.php?nam ... ic&t=21708
Post Posted: Fri May 06, 2011 9:39 am
yer would be good just dont really have the money yet to afford the gti seats , and dont know how to fit them as they wouldnt just go straight in the sierra tracks
Post Posted: Fri May 06, 2011 9:42 am
im pretty sure for GTI seats you just drill a new hole on the rail and it bolts right on? Ask in the suzuki section, someone will know off the top of their head.
$150 is really good price wise.
Post Posted: Fri May 06, 2011 9:48 am
Fitting GTI Seats:
http://www.auszookers.com/index.php?nam ... +gti+seats
Post Posted: Fri May 06, 2011 5:37 pm
might not be what you are thinking.. but i did this to mine, because my seats were ruined.
http://www.auszookers.com/index.php?nam ... ic&t=19205
Post Posted: Sun May 08, 2011 3:59 pm
I just fitted mine tonight and it was a pretty simple mod
Use the Sierra rails and you need to drill 2 new holes and elongate 2 others
On the drivers side i used the rear holes as a guide and had to redrill the front holes. It doesn't have a nutsert in the rails...just holes (GTi seats bolt to the side of the seat and not under...if that makes sense) so you will need a nut/bolt to make it work. I also fitted some washers. The original Sierra bolts are smaller than the GTi ones but if you have the GTi rails just use those bolts...you will need to find nuts to fit though.
On the passanger side i use the front hole as a guide instead of the rear (already has threaded hole for the bolt) and then elongate the hole on the rail and drill a new hole in the "seat" at the rear. You will need to cut the fabric of the seat which will expose a pre-drilled hole that is "out of centre" for the rail. You will need to drill a new hole above the existing one and then just bolt the sierra rails on. (Make sure you put some washers so the bolt doesn't slip through the hole)
I would strongly recommend using the GTi seats over the Autotechnica seats as i have both (one in each zook) and prefer the GTi seats....much more comfortable and fit much better :-)
I've got 2 sets of Sierra seats (each set from each zook)....one in decent condition and the others are ripped. If you're interested just shoot me a PM
Users browsing this forum: No registered users and 101 guests
