It is currently Sun Oct 04, 2026 9:34 am
Post Posted: Thu Aug 28, 2008 7:33 pm
What size tyres can I fit to my 93 vitara 4 door that won't change the gearing to much or through to much load on bearings and cv's.
It gets used for general highway use as well as fire trails.
I have 2'' suspension lift and will add 2" body lift in the next few weeks.
Post Posted: Thu Aug 28, 2008 7:35 pm
235's or 30inch tyres.
Post Posted: Thu Aug 28, 2008 7:39 pm
Thanks mate - I guess they would be better on sunraysia rims,
but what size rim?
Post Posted: Sun Aug 31, 2008 1:07 am
I would use a 15x 8 rim try a f100 off set
 Profile YIM
Post Posted: Sun Aug 31, 2008 1:30 am
watch out for f100 rims in the 8 inch size as the offset my be a problem. the more offset the more likely the tyre is going to foul on the rear arch lip as offset increases the movement within the turnig arch. with a tyre like a 235 or 30 a 7 inch sunny with no offset should be better. but if you have a suspension and body lift and 8 inch rim should be ok, but might be a bit wide for that size tyre.
Post Posted: Sun Aug 31, 2008 5:27 pm
Thanks - I will do the body lift and then start to look at tyres and rims.
Users browsing this forum: Google [Bot] and 220 guests
