It is currently Sun Sep 20, 2026 8:49 pm
Post Posted: Tue May 10, 2011 7:01 am
OK thought I had lost spark but it turns out the pin locating the Cam pulley has gone AWOL.
Any suggestions on how to fix it?
My thoughts are find a tight fitting twist drill. Heat the end of the cam and guide it home with a hammer. Grind off the end at a suitable length.
or
Maybe locktight a drill in as the heat may effect the seal integrity.
SS
Post Posted: Tue May 10, 2011 7:07 am
can u buy a new pin from suzuki?
Post Posted: Tue May 10, 2011 7:11 am
Another option might be to rat one out of another cam?
Post Posted: Tue May 10, 2011 7:19 am
2 roll pins, one inside the other, ground off to the right length?
Post Posted: Tue May 10, 2011 7:34 am
Cut down a drill bit
Lil Foot!
Post Posted: Tue May 10, 2011 7:58 am
get another from another cam or engineering shop and loctite that in
right tool for the job bla bla bla
Post Posted: Tue May 10, 2011 8:06 am
Thanks for the responses.
I'll try and source a spare from another cam or suzuki and locktight it in.
This motor needs to be reliable its off to the Cape in 6 weeks! Starting to think I'm a bit :crazy:
SS
Post Posted: Tue May 10, 2011 8:09 am
Plenty of AZ assistance till you hit Cairns, then you're on your own :lol:
Post Posted: Tue May 10, 2011 8:10 am
I'd either fit a new pin or tap it and fit a bolt with head cut off after install.
Post Posted: Fri May 13, 2011 10:38 am
Any engine reconditioning place, or even clutch place will have plenty of dowels lying around.
I wouldn't use the drill bit, as it is too brittle, however you can use the shank of the drill bit to figure out your required diameter.
All major fastener places also sell round stock in small lengths.
Hope that helps you out.....
Post Posted: Sat May 14, 2011 7:08 am
I have gone down the drill shank track path as it will be a tempory fix. I'm going to change the head soon. :)
I think why it came out was due to the pulley bolt not having the thick washer underneath it. I also attached the pulley using some 609 loctite on the mating surfaces. The pin itself should only be for locating the pulley for correct timing not taking any load of the cam shaft rotation.
SS
Post Posted: Sat May 14, 2011 9:06 am
Look at the bottom of the page, other issues caused this... (oil pickup was stupidly blocked)
http://auszookers.com/index.php?name=Fo ... sc&start=0
Post Posted: Sat May 14, 2011 9:10 am
So the cam ( being the last to get oil pressure) was seizing.... :P
Post Posted: Sat May 14, 2011 9:16 am
yup. still destroyed the cam gear good. And in the search for a new one, out of 4 that we found, only one didnt have similar damage (just not as bad)
Users browsing this forum: No registered users and 197 guests
