It is currently Wed Oct 07, 2026 6:23 pm
Post Posted: Tue May 10, 2011 11:05 am
when i turn my ignition normaly my stereo will turn on aswell (as it should) but recently it has stopped doing this. i origionaly started that the stereo would run but as soon as u turned another electronic device on eg indictaors, or hit the brake pedel it would cut out. this is very annoying now its at the point u tunr the ignition on and if ur lucky the buttons might flash randomly a few times. the screen dosent even light up. but the indicators and stuff still run and the batterie will still have enough power to turn the engine over. it would origional fix when the engine was on. but now it will cut out (turn of completely) when the engine is on and an indicator or brake lights. the stereo has always cut out when u plug somthing in the cigeret lighter.
HELP ME PLEASE
cheers troy
THINKING BEFORE POSTING!!!
Post Posted: Tue May 10, 2011 11:09 am
Try a new earth
Post Posted: Tue May 10, 2011 11:11 am
Try adding dirty great big earth strap from the battery negative to the body.
My sierra was playing sily buggers, temp gauge going up when the lights on, lights dull, indicators would please themselves whether they would work or not, I added a big welding lead earth, bingo, no dramas.
I don't understand, but it worked.
Post Posted: Tue May 10, 2011 11:13 am
hhhmmm cheers boys ill give it a try and let yas know.
Post Posted: Tue May 10, 2011 11:33 am
nope no help. will check the earth on the deck tomoz though. thats the only thing thats playying up and the person that wired it in the first place looks a bit dodge. (wired just twisted together and shit) but i already fixed anytjing like that i could find
Post Posted: Tue May 10, 2011 11:48 am
What did you use for your earth, where did you put it ?
Post Posted: Tue May 10, 2011 11:58 am
i just used a bit of wire for a test. its about 10-15mm insulated copper wire with two eyes crimmed on. (dads old winch wire left over piece) bout half a meter long. tried it on three different clean bolts including the headlight earth
Post Posted: Tue May 10, 2011 12:06 pm
That should have done it if the earth was to fault. Scratch earth.
Post Posted: Tue May 10, 2011 12:53 pm
bleh i can see me having to rip the dash out to fix this.... sigh. was supposed to be having a play this weekend
Post Posted: Tue May 10, 2011 1:07 pm
Best music on earth is the one that your engine sings you when your working her really hard, wide open throttle, pedal to medal, 3-6,000 revs.
Post Posted: Tue May 10, 2011 1:18 pm
pedal to the medal at 3 grand. hahaha i have to wind it up to 4 to change gears atm
Post Posted: Tue May 10, 2011 1:23 pm
No shit, mine will pull away in top gear, at around 35k with no worries, stock gears on 31s
I very seldom go over 2500 on the blacktop when up shifting, no need, she pulls well.
This is why your on about emission controls, power up ?
Post Posted: Tue May 10, 2011 1:27 pm
yeah. i got a webber on to. should be pissinalong. only got stockie tyres but. is going of to the doctor on thursday. hopfully it will come back with more power. if not ill probs do the exaust and shit
Post Posted: Tue May 10, 2011 1:33 pm
You have a bad prob there, weber, and having to go to 4k or over to upshift.
Let us know what she is like when she comes back from the docs.
Webers are very easy to tune, bout the simplest to work on there is.
Post Posted: Tue May 10, 2011 1:36 pm
Here, is a ripper site, lots of good info, and a how to work a weber, really worth a read.
They make the lil zook fly.
Post Posted: Tue May 10, 2011 2:23 pm
the mechanic is one of my mates dads. i dont have to up shift at 4 grand. but i do mostly highway driving so. unless ya like getting over taken by road trains when ur taking of at the lights kinda gota rev shit out of it. (zuke loves it but) probs why my fuel economy is so shit aswell. im realy hoping that the timing is out a fair bit. timing fixed, all round tune up and jets checked/ replaced and my lil rally car will be loving it.
Vehicle: Jeep
Post Posted: Tue May 10, 2011 5:05 pm
A better 2in exhaust will really be able to make full use of the weber... some stock exhaust systems recirculate burnt exhaust gases back into the combustion chamber, giving it a unclean burn, once the exhaust gases can get out better, you get almost no recirculation, and a much cleaner burn in the combustion chamber, taking better advantage of the improved air/fuel mix from the weber, which means it breathes and farts alot better ! :wink: :lol:
Post Posted: Tue May 10, 2011 11:33 pm
it dose have a new exaust but it looks identical to the stock one.
Post Posted: Tue May 10, 2011 11:41 pm
None of this is helping with your electrical problem. Put a multimeter on the back of the alternator and tell us how many volts are coming out, both at idle and at revs.
Post Posted: Wed May 11, 2011 1:39 am
Hey mate.
I had some similar dramas to what your describing with your head unit. The thing would "reset" itself when i applied the brakes/headlights etc.
I've done a few installs so decided to tear it apart and see what was happening. From what i could tell whoever did the install got a switched 12V from wherever they could find it. It must have been getting interference and slightly dropping voltage enough to get the head unit to reset.
What i did with mine was trace out the constant and switched 12v for the head unit and relocate them with a clean source. i.e a direct battery feed to the fuse box and a main and clean switched 12v. This fixed my dramas and touch wood its fixed the problem.
May sound like a stuff around but once its done it should sort your dramas
Post Posted: Wed May 11, 2011 2:45 am
i think there is a spare accsesry wire were i pulled the clock out. i got the uhf runing of of the hot wire from that. i belive that the wire i want is yellow right.
Post Posted: Wed May 11, 2011 2:28 pm
think i found the problem. fuse box is full of brake fluid.
Users browsing this forum: Google [Bot] and 182 guests
