It is currently Thu Oct 08, 2026 3:14 am
Vehicle: Work van
Post Posted: Tue May 10, 2011 9:40 pm
Hi guys I'm in the process of moving my front spring perches on my hilux diffs to suit my widetrack and I'm just after the measurement between the spring locating pins, I did search but couldn't find a measurement :D
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Post Posted: Tue May 10, 2011 11:45 pm
Anyone who runs hilux diffs use the hilux spacing as the WT is too narrow and you will run into spring mounting in pumpkin problems.
The Hilux diff perch is already modified to get it closer to the pumpkin standard. Any more will need cutting of the housing.
Post Posted: Tue May 10, 2011 11:46 pm
Im pretty sure you can use WT spacing but not NT
Post Posted: Tue May 10, 2011 11:55 pm
If your after the wt spacing I think it's 950mm center hole to center hole
Can't quite remember but I'm 99% sure
Vehicle: Work van
Post Posted: Tue May 10, 2011 11:57 pm
I've got the kit which welds to the original drivers side perch :D Just need a measurement for the passenger side, but can't get the car until the weekend and was hopin to have the diff done tonight
Post Posted: Tue May 10, 2011 11:59 pm
Shit dont listen to me that's the rear Diff spacing not the front
Post Posted: Wed May 11, 2011 12:20 am
if you have the sky kit mount that and stick the diff under the car to set the passenger perch in place. You can double check it is centered by measuring from the end of the diff to the spring on both sides.
Users browsing this forum: No registered users and 160 guests
