| Author |
Message |
selaga
Joined: Wed Oct 07, 2009 10:30 pm Posts: 137 Location: SYDNEY 2767
 Posted: Sat Apr 30, 2011 7:20 am |
Greetings to all,
I am looking for another Suzuki, after having owned a few Jimmny's, SWB Vitaras, and couple of WT Sierra's, even a high roof Drover once tht I bough from GM Spares in Yenorra for $250 (long time a go...)....
We are looking at a low kay 1995 H20 LWB Vitara, as a compromise between touring/comfort and hard core 4by.
Is there anything SPECIFIC that I need to look at regarding this particular model ? Is there much scope to turn it into a mid level offroad vehicle (30/31's/2"BL+2"spring) ? Is it hard to get a rear locker for this unit ?
Did this model have the steel Front Diff housing ?
Any feedback/advice would be greatly appreciated.
Fatzook
 Posted: Sat Apr 30, 2011 7:41 am |
No steel diff.
Listen carefully to the motor for timing chain rattle.
atari4x4
 Posted: Sat Apr 30, 2011 7:51 am |
air lockers are available front & rear, same with auto lockers.
selaga
 Posted: Sat Apr 30, 2011 8:15 am |
Fatzook wrote: No steel diff.
OK.Is it more likely to manifest itself when cold or hot ?
Fatzook
 Posted: Sat Apr 30, 2011 8:18 am |
Both. Of it goes away once warmed up, you may want to put that on the to-do list. If it doesn't shut up it will need doing immediately. Not sure what that costs, but parts alone are about $800 I think.
One of the mechanics will chime in soon no doubt... Stek? Scrawn?.........Royce?
royce
 Posted: Sat Apr 30, 2011 8:21 am |
yeah rattle is mainly at startup till it gets oil pressure
there is nothing else wrong with em, they are a vitara afterall
just remember its a 16yo car so lots of bits could be stuffed or new, things like bearings, fuel pump, radiator, bushes are all things to check out
steak_knife
 Posted: Sat Apr 30, 2011 8:39 am |
royce wrote: yeah rattle is mainly at startup till it gets oil pressure
there is nothing else wrong with em, they are a vitara afterall  just remember its a 16yo car so lots of bits could be stuffed or new, things like bearings, fuel pump, radiator, bushes are all things to check out
Unless the tensioner is the ole style one, then it will rattle all the time.
Timing cover's like to leak oil to.
nissvit
Joined: Sun Apr 06, 2008 11:30 pm Posts: 184 Location: Brisbane
 Posted: Sat Apr 30, 2011 8:43 am |
hi,
they use the same rear suspension as the early vits ie they use a heim joint ( ball joint) to locate the top of the diff. these joints seem to wear out pretty quickly with the additional pwer of the v6, but any heim joint of a standard vit will fit it.
they use a gearbox & transfer case that is more closely related to the standard vits than the GV's.
the front suspension uses cast lower arms like the GV's do.
selaga
Thanks for all advice, I will go through it thoroughly, I don't expect too many isues with the kays it has travelled (150-ish).
I will keep you all posted on how I go on Monday.
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Sat Apr 30, 2011 8:52 am |
royce wrote: there is nothing else wrong with em, they are a vitara afterall
 Front diff
nissvit
 Posted: Sat Apr 30, 2011 9:19 am |
when you are looking at the body, open the rear door and look up,
the seam just at the top where the door recess is seems to be the place that rusts first in the lwb vits..
steak_knife
 Posted: Sat Apr 30, 2011 9:27 am |
nissvit wrote: when you are looking at the body, open the rear door and look up, the seam just at the top where the door recess is seems to be the place that rusts first in the lwb vits..
 I learned some thing today!!!!
steak_knife
that should be the same with the h/top 3 door's to then!!!
royce
 Posted: Sat Apr 30, 2011 11:11 am |
steak_knife wrote: that should be the same with the h/top 3 door's to then!!!
mines always looked crappy, but it has ERPS so its fine
selaga
 Posted: Sun May 01, 2011 4:43 am |
steak_knife wrote: nissvit wrote: when you are looking at the body, open the rear door and look up, the seam just at the top where the door recess is seems to be the place that rusts first in the lwb vits..  I learned some thing today!!!!
Will do...I will also see the top of the rear tailgate opening where the rubber traps the dirt...
I think the front diff will be OK for the type of driving I planned to use it for.
If it breaks, well then I can always put the steel version in.......
I think they run 16" wheels ? Hopefuly that wont limit the tyre choices ? I really like the BFG AT's........
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Sun May 01, 2011 4:59 am |
check the fuel box under the dash, if it looks melted stay away. i know of 3 different lwb vitaras that have had under dash fires started by wiring.
selaga
 Posted: Sun May 01, 2011 5:14 am |
Well what a shit two weks it has been.....The seller jerked me around for five days, wouldn't commit to a time, and then when we made a time to see the Vit, he would change it, etc.....Then on Friday, the tool #1 rings me and says let go for SAT morning, I ring him on SAT morning and he tells me he sold it to his neighbour........
Car two, got passed in on Ebay, I make an offer, I offer to pick it up and pay on the spot. Seller excepts the offer, and asks me to pick it up in two days so he can transfer his personal content number plates. I take a day off work, and about to catch a train up the coast to pick it up,and tool #2 rings me and told me he sold it for $500 above my offer upon which we agreed on........
Doesn't anyone stick to their word anymore, or am I too "old school", when your word was your bond ?
Today my luck changed, a picked up a 1998 GV with the H25 and AUTO from deceased estate for a bargain, so will post up a few pics shortly. Apart from a small miss, it drives perfect, I suspect a dodgy spark plug and/or coil....
selaga
 Posted: Fri May 13, 2011 10:45 am |
Fixed the miss, new plugs, and coil tube #1 and #1 had water in them.
Good thing is no need to remove the inlet manifold, simple 30 min job.
Runs like a clock now, plenty of power.......
Tomorrow I iwll put all new globes in the front lights and polish the acrylic lenses on the headlights.
fordem
Joined: Mon Apr 19, 2010 11:30 pm Posts: 2658 Location: Georgetown, Guyana
 Posted: Fri May 13, 2011 12:17 pm |
selaga wrote: Today my luck changed, a picked up a 1998 GV with the H25 and AUTO from deceased estate for a bargain, so will post up a few pics shortly. Apart from a small miss, it drives perfect, I suspect a dodgy spark plug and/or coil....
I'd say your luck hasn't changed - it was good all along - you just need to look at events from the right perspective - you good luck stopped you from buying a V6 Vitara and pointed you to a much nicer vehicle.
But - all the same - it does make you wonder about people doesn't it?
