It is currently Fri Oct 30, 2026 4:06 am
Vehicle: Sj70 tintop
Post Posted: Fri May 13, 2011 11:19 am
im after a winch bar (arb, tube whatever) and a 1.3 w/t transfer in vgc condition, with or without reduction gears.
cheers
joel
Sj70 tintop
Post Posted: Fri May 13, 2011 11:25 am
cheers
joel
i have a 1.0 box that is the same case as a 1.3. your ute transfer should
be able to take gears as well.
Post Posted: Fri May 13, 2011 11:44 am
the ute has a 1 liter still in it.
just thought a 1.3 case and gears would gear it down a bit more. whats the 1liter case is equal to a 1.3 with what gears?
Sj70 tintop
Post Posted: Fri May 13, 2011 12:41 pm
Nope. 1L is lower than 1.3. Keep what you have. :wink:
Post Posted: Fri May 13, 2011 1:01 pm
how much lower? i was aware its a cheap alternative for 1.3 owners to gear them down, but i want to run 31s and maybe 33s later on so i was going to get a 1.3 case and throw some 5.14:1 in it, or will it be little gain over the 1liter case.
Sj70 tintop
Post Posted: Fri May 13, 2011 1:09 pm
You have a late model Maruti, so your case is EXACTLY the same as a WT 1.3L sierra case, only your gears are lower (12% in high).
Just buy the gearset you want and install into YOUR case. :wink:
If you are considering 33's then get 6.5's straight up. :wink:
Post Posted: Fri May 13, 2011 1:19 pm
sweet i will check it out when i can see it.
still need a bar.
Sj70 tintop
Users browsing this forum: No registered users and 80 guests
