It is currently Thu Oct 22, 2026 12:37 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Post Posted: Sun May 15, 2011 7:16 am
OK seeing so many of you suck at electricity so much :lol: ive decided to do something about it.
Whilst doing something about it I made some clicky starter fix relays, all you need to do is screw the relay to the firewall (will reach to behind the battery), unplug the original starter wire, plug it into the loom, plug a new wire onto teh starter and bolt the power wire under the main power stud and you are away
All connections soldered and crimped, split loom tubing and heatshrink, this could well be the nicest thing in your sierra engine bay.
Will also fit Vitaras and pretty well any car in the world if you feel the need to have one.
$30 posted in Australia, all proceeds go to Auszookers
Post Posted: Sun May 15, 2011 7:42 am
I've read about these clicky starter fixes. But what is the "clicky starter"? Is it a problem that happens to most zooks? Or is it the same on all zooks from factory?
Nice. Do they work on J20's ? :lol:
And why use split corro? For that short length You could use the un-split flexi conduit. Just pre-drill your exit for the earth. :wink:
Vehicle: Daisy
Post Posted: Sun May 15, 2011 7:50 am
I had it, then I checked the connection on the starter and battery and the problem was fixed!
These look like a bloody good idea though!
Post Posted: Sun May 15, 2011 7:54 am
All my wiring is in split conduit then taped up the whole length.
Oh so it's just one of those things that happen not a design flaw.
Post Posted: Sun May 15, 2011 8:00 am
Sounds like too much work :lol:
Good job Royce.....again, to late for me to buy one :roll:
Vehicle: LWB Sierra & XL7
Post Posted: Sun May 15, 2011 8:11 am
I think mine has been needing one of these.
Is this the symptom of a clicky starter that needs a fix?
I turn the key, and click.
Sometimes it will turn over if I hold the key, other times I have to back off and do it again, sometimes a few times.
My auto elecy explained that the solonoid will stick especially if it's very dusty or if mud has gotten in.
'92 Vitara & Camper trailer
Post Posted: Sun May 15, 2011 8:35 am
Get a fat chunk of cable, one end to the battery positive, the other end to the start solenoid terminal, if it cranks easy you could do with one (I think all vits are relayed though factory)
Post Posted: Sun May 15, 2011 8:36 am
Ahhh! I'm with it now. My old one did that..
Vehicle: 91 WT 1.6EFI
Post Posted: Sun May 15, 2011 1:29 pm
If you own a sierra just buy one of these now and save your self the trouble later... its going to happen to you eventually.
Vehicle: 96 coily Awesome sticker Rust
Post Posted: Mon May 16, 2011 6:31 am
How much spare time have you got to be sitting at home soldering all this together
I think Ted Kaczynski started like this 8O
I have issues
What are you looking at
Post Posted: Mon May 16, 2011 6:40 am
Royce, wouldn't dirty great big leads, unlike the anorexic standard ones do the same.
I had a slow as starter, rrrer, rrrrer, yuk, put the multimeter on, lots of power drop tween battery and starter, so used 300amp welding leads as to starter, both + and -, now, its like a friggin die grinder.
I love big heavy duty leads, the ones on sierras are extremely cheap and nasty.
Post Posted: Mon May 16, 2011 10:20 am
Just running a straight starter switch like a Ferrari 8)
except not quite as fast :oops:
it's old school but maximum power to the starter :twisted:
I have issues
Post Posted: Mon May 16, 2011 10:22 am
different part, no good having 1000amps available to teh starter if the key is flogged and it cant pull the solenoid in properly
Post Posted: Mon May 16, 2011 11:23 am
This ^^^ is why mine works
like a veyron brrmmmmmmmmmm brrrrrrrrrrrrrrrrrrrm brm cough cough splutter brm
Also looks cool when you push the button and the car starts....
or when people turn the ignition all the way and nothing goes...
until you push the starter button vroom vroom vrrroooooom
I have issues
Post Posted: Mon May 16, 2011 1:07 pm
i can so see you sitting in your zuk in the carport making those noises and turning the wheel and playing with all the levers and buttons =P haha
Post Posted: Mon May 16, 2011 1:10 pm
^^^x2^^^
dodgy brothers mechanical
Vehicle: Jeep
Post Posted: Mon May 16, 2011 4:24 pm
My 89 Vit developed the clicky starter... i replaced the starter motor thinkin it was that... but still did it... took it to Suzistore, they knew what it was straight away... there is a section of plugin cables, about 40cm long, that go from the firewall to the steering column, had a dodgy wire in it, they replaced it with a 2nd hand one... problem fixed... :wink: :lol:
Post Posted: Tue May 17, 2011 1:39 am
http://www.msnbc.msn.com/id/43018563/ns ... -security/
Post Posted: Tue May 17, 2011 2:07 am
Forgive my ignorance here, but if its the key, can't you just get a new one cut.
I had a key that would fall out of te barrel on bummpy roads, and yet the engine would run fine.
Went to a locksmith, not a key cutter, but a full on locksmith, he got the details of my car, had to show proof of ownership, went on the computer, looked up the barrel id, cut a new key, alls well.
Post Posted: Tue May 17, 2011 2:14 am
Stop being difficult and buy one :roll:
its all to do with voltage drop, ive already posted a long winded explanation of why sierra electrics suck and how they can be improved, this is one of them improvements
Post Posted: Tue May 17, 2011 2:23 am
lol sorry boss, on shore, bored, mkay.
Post Posted: Tue May 17, 2011 2:40 am
hay royce how many rolls of cloth tap for one i could make my own but know you love the stuff lol
Post Posted: Tue May 17, 2011 2:41 am
how many have you got :)
Post Posted: Tue May 17, 2011 3:54 am
Spooky similarity some would say
I have issues
Post Posted: Tue May 17, 2011 4:00 am
Shouldn't this thread be in chat? :P
Lil Foot!
Post Posted: Fri May 20, 2011 10:08 am
Post Posted: Fri May 20, 2011 10:10 am
8O
Post Posted: Fri May 20, 2011 10:12 am
Royce, you should do a headlight upgrade loom ;)
helloo
Post Posted: Fri May 20, 2011 10:13 am
You should read the whole forum :thefinger:
Users browsing this forum: No registered users and 31 guests
