It is currently Fri Sep 25, 2026 12:10 am
Post Posted: Tue May 17, 2011 2:46 am
[img][IMG]http://img580.imageshack.us/img580/4223/mudzuk031.jpg[/img][/img]Not only have I got a screw loose, my motor has two loose, so loose that they have run away 8O I can't see them anywhere in the head either :? Where could they have gone? :?
[img][IMG]http://img543.imageshack.us/img543/6779/mudzuk030.jpg[/img][/img]
[img][IMG]http://img863.imageshack.us/img863/2711/mudzuk029.jpg[/img][/img]
[img][IMG]http://img189.imageshack.us/img189/1158/mudzuk032.jpg[/img][/img]
Vehicle: lj81 stockman
Post Posted: Tue May 17, 2011 2:47 am
sump
the wobble rocks
Post Posted: Tue May 17, 2011 2:55 am
Dunno where they have gone, but its a pretty normal thing to see once the rocker cover is lifted, a screw loose in a sierra is normal.
er, a 1.3l that is.
Post Posted: Tue May 17, 2011 2:57 am
Yeah, I have heard of this, so thought i'd check
Post Posted: Tue May 17, 2011 3:02 am
Found mine up top, was pretty hidden.
Post Posted: Tue May 17, 2011 3:05 am
i had one jammed in the corner where the oil goes though its still there its stuck good
Post Posted: Tue May 17, 2011 3:13 am
now going to check mine
Post Posted: Tue May 17, 2011 7:41 am
Use a very good lock tite product, it is a known problem.
If engine still running, screws are hopefully somewhere safe
Post Posted: Tue May 17, 2011 7:52 am
I use loctite on them and then after fitting I use a centre punch to peen between the screw and the alloy it goes into..
The combination makes it impossible for them to come out.
If you ever have to remove them, a good wack in the middle of the X with a small ball-pein hammer breaks the seal.
Post Posted: Wed May 18, 2011 3:38 pm
excellent advice for a common problem, hope you find your screw!
Post Posted: Wed May 18, 2011 7:02 pm
Nah, just put two new ones in. :(
Post Posted: Wed May 18, 2011 8:09 pm
Go hunting with a telescopic magnet in the top end and if no luck, sump off and go swimming around in there with the magnet
Post Posted: Thu May 19, 2011 5:18 am
Can't be bothered, it's still going :lol:
Post Posted: Thu May 19, 2011 5:31 am
All the more reason to do it !! If the engine picks one up it will do damage, but with that attitude good luck mate.
Post Posted: Thu May 19, 2011 5:34 am
Could they damage the engine? Thought if they were in the sump that they would stay there? :(
Post Posted: Thu May 19, 2011 5:38 am
This may not matter to you but oil will piss out those holes and not lubricate the rockers correctly , causing them to damage the camshaft and bearings , is it still piss funny , Cheers Paul.
Post Posted: Thu May 19, 2011 5:43 am
What about if you tipped upside down, and could not get the engine off straight away, and it ran, screws went up, lock your engine solid, rotating mass tore threw the seizure, exploding the engine, sending shrapnell for miles, everyone dead, birds, n other things you have over there, maimed, and in terrible pain.
You are found out to be the direct cause of this, coz one of the screws were found, and then a lynch mob came for ya.
hmmm, don't say you havn't been warned. 8O
Vehicle: '92 Sierra
Post Posted: Thu May 19, 2011 5:49 am
At least then that would take the spotlight of BP for the oil spill in the states.
Post Posted: Thu May 19, 2011 5:52 am
ahh a, always look on the bright side of life.
BP would be most greatful lol.
Post Posted: Thu May 19, 2011 7:26 pm
I put more screws in :wink:
Post Posted: Thu May 19, 2011 7:35 pm
drain your oil and use a flexy magnet up the drain plug and have a dig around
Users browsing this forum: Bing [Bot] and 173 guests
