It is currently Tue Jul 28, 2026 4:58 pm
Post Posted: Wed May 18, 2011 8:09 am
Hey guys got my airlocker and cromoly axles yesterday (well actualy half of the cromolys :cry: )
just wondering how hard it is to fit the locker, I am very mechanical minded
And can do it if I put my mind to it.
I guess it will be easy to follow the instructions.
Or should I leave it up to the pro's
I don't really like the idea paying a mechanic to do some thing I might be able to do
Post Posted: Wed May 18, 2011 8:15 am
i think its just a case of warranty, if you fit it, and something goes wrong, there's no warranty involved. 99% sure this is the case
Post Posted: Wed May 18, 2011 8:19 am
That's what I was thinking, but still arb will want my arm nd leg to do it
Post Posted: Wed May 18, 2011 8:38 am
i personally would get them to do it, knowing i could probably fit it myself, but i'd be kicking myself if something went wrong with it and had to fix it myself. how much do they want to fit it?
Post Posted: Wed May 18, 2011 8:44 am
If you buy a diff rebuild kit from lowrange offroad
I can rebuild your diff and install the air locker to your centre for $300
You R&R the diff centre and fit the compressor and air line
I've worked as a Suzuki mechanic, arb and as a heavy vehicle mechanic with 10yrs exp
I've done diffs for plenty of Auszookers members and never had any complaints and I've been recommended by other members.
I rebuilt the rear air locker in team tough turtle that entered in tuff truck this year without failure.
Pm me if your interested
Post Posted: Wed May 18, 2011 8:45 am
Not sure how much havnt ask yet
But it's arb we are talking about
This is why I got my locker from the states not here in aus
Not even sure if they will fit it since I didn't buy it of them but they should
I might just get them to fit it
Does any one know how much it cost before I ring them
It's a couple hundred dollars if they had to pull the shafts nd center out of the diff them selfs I'm guessing
But I'll just take the center into arb
Post Posted: Wed May 18, 2011 8:49 am
last time i checked ARB wants $383 for fitting (2yrs ago) and that's just fitting the locker... not rebuilding the diff & fitting the locker as quoted by oozuk
Post Posted: Wed May 18, 2011 8:50 am
Diffs are rebuilt already
Only thing I didn't do is the pinion bearing and seal
I'll send you a pm
Post Posted: Wed May 18, 2011 8:53 am
i often go running through bethania, and i've never seen that zook in your avatar driving. thats a good offer too. i'll have to remember that one
Post Posted: Wed May 18, 2011 9:02 am
That's because it spends most of it's life under lock and key in the shed.
Post Posted: Wed May 18, 2011 9:10 am
I'll send you a pm
If the diff pinion bearings and pinion seal haven't been replaced then in my opnion that diff has not been rebuilt, but if your only wanting to have the air locker installed I at least ask that you have fresh carrier bearing fitted to the air locker.
Post Posted: Wed May 18, 2011 9:21 am
Oh you mean rebuild the centers
I mean the diffs are rebuilt
I havnt touch the centers yet
Wasn't going to cos thought they were pretty good
I guess it shopping time for me At LWOR again
Post Posted: Wed May 18, 2011 9:24 am
And usually 9 times out of 10 the old carrier bearings can get damaged when pulled off the old carrier, that's why I say at a minimum to do the carrier bearings.
Post Posted: Wed May 18, 2011 9:27 am
Ok I'll get pinion seal and bearing and a Carrier bearing
Any thing else
Post Posted: Wed May 18, 2011 9:44 am
Any thing else
Yeah the pinion crush tube as there single use
Low range off road do a kit where you get pinion and carrier bearings, pinion seal, crush tube, new pinion nut, liquid sealant for installation and diff setup paint.
Your best to get that in one go from lowrange as it will be heaps cheaper from them than any one else.
Post Posted: Wed May 18, 2011 10:19 am
oozuk wrote:
Any thing else
Ordered plus other stuff :D
Yay more stickers
Users browsing this forum: No registered users and 418 guests
