It is currently Sat Aug 01, 2026 5:20 pm
Post Posted: Sat Feb 19, 2011 4:37 am
Did a service on the jimny today and was gonna quickly change the drivebelts but have come across a bit of dilemma of how ure spose to adjust/ remove the belt that runs the aircon and power steerin.
Its probaly something simple but me being on the soup all day doesnt help.
Any ideas?
Its the M13A donk
Doug
Post Posted: Sat Feb 19, 2011 4:58 am
there is a little tension pulley on there. smallest pulley on the belt.
has two nuts on it. loosen both of those and it will let the tension off.
should be able to work the rest out from there
Post Posted: Sat Feb 19, 2011 5:04 am
yep yep i see says the blind man, Might attack it tomorrow i thinks
Thx
Doug
Post Posted: Sat Feb 19, 2011 5:35 am
any time =]
wont be easy to get on and off still....
if you have trouble you can slowly turn over the engine using the bolt on the crank pulley and "roll" the new belts on.
Post Posted: Sat Feb 19, 2011 6:13 am
Yeah its in a bastard of a spot, very tight squeeze!
Doug
Post Posted: Sat Feb 19, 2011 7:23 am
10mm Alan key goes into the one with the bolt, swing off it(alan key)to get tension & do the nut up..
They like to be tight, lot's tight, or they WILL squeal like a squealy thing.
Post Posted: Sat May 21, 2011 4:33 am
Ok, so I have just tightened both the belts on my Jimny. I found that an 8mm (not a 10mm) Allen Key was what fitted into the idler/tension pulley/wheel beside the resessed bolt, but I could only get it to tighten a little. I think this is because if you push the Allen Key in to far through the hole it fouls on the pulley mount behind.
Even if you bring the Allen Key out so it does not foul, it still does not allow enough movement to get the required tension.
The only solution I came up with was using a Tyre Lever against the top of the idler and a pipe bolt just above, using quite a lot of force to get tension. This has to be done carefully of course, so as to not damage the idler puller.
In regards to the alternator pulley, I had to do a similar thing and could only get enough tension using a tyre lever between the inside of the alternator and the mount above.
With both of these tensioned sufficiently, I have relieved the occasional squeak (from the alt belt) I get when its cold and allowed the AC pulley to turn properly even when wet.
Post Posted: Sat May 21, 2011 4:57 am
can some one delete this shit!!!!!!!!!
The Suzuki tool is a 10mm, so if your useing an 8mm, yours is stamped wrong!!!!
I have cut down 4 10mm allen key's over the yr's to replace one's apprentice's have lost...
Post Posted: Sat May 21, 2011 6:38 am
You might very well be right, in fact you probably are. I am often wrong.
Where can I post the Micky Mouse badge?
Post Posted: Sat May 21, 2011 9:22 am
Stop posting SHIT then..... :helloo:
Post Posted: Sat May 21, 2011 11:10 pm
I ended up threading the nut! So took of all the fan and shrouding to get the nut off, eventually got it off and put a new bolt on. made it so much easier with all the fan and shrouding out of the way to tension the belts.
Doug
Post Posted: Mon May 23, 2011 2:16 am
Ok, I will do my best.
You can apologize to me any time though thanks Steve. :helloo:
Post Posted: Mon May 23, 2011 2:17 am
That it would. Have fun doing that EVERY time you need to adjust a belt :P
Post Posted: Mon May 23, 2011 5:33 am
with my fat hands it makes it a shit load easier, plus its only like 6 bolts on the fan and 4 on the shrouding than bobs ya uncle
Doug
Users browsing this forum: Google [Bot], Jezzer and 353 guests
