It is currently Tue Jul 28, 2026 8:59 pm
Post Posted: Fri May 27, 2011 2:21 am
I've got 6.5 gears in my transfer case. I put them in a few years ago. on all the flanges there is a fair bit of movement up and down. It's not noisy but the movement seem excessive.
I'm not sure if it's bearings or thrust washer issues?
Vehicle: MY2019 Jimny
Post Posted: Fri May 27, 2011 3:58 am
I'm not sure, but I would think your bearings may have seen better days.
Come to think of it, I think my front output shaft had a bit of movement when rebuilt...
Vehicle: Daisy
Post Posted: Fri May 27, 2011 9:09 pm
Is it the flange moving up and down/side to side on the shaft?
Or
Is it the shafts moving up and down/side to side compared to the transfer?
Post Posted: Fri May 27, 2011 11:59 pm
First thing, check that your flange nuts are tight, If they have been loose for some time the splines wear and can give movement
Suzuki is my way of life.
Post Posted: Sat May 28, 2011 4:15 am
flanges are tight, and have been tight since put the gears in. movement is the whole shaft.
Post Posted: Sat May 28, 2011 6:04 am
bearings..........
Post Posted: Sat May 28, 2011 7:10 am
X2.
Thrust washers worn would create in-out movement, not up and down.
Post Posted: Thu Jun 02, 2011 10:27 pm
does anyone know the part numbers for the bearings in the transfer, i was going to order them before i pull it apart.
I was also wondering if the speedo drive of a 1litre transfer case fits into the 1.3. the 1 litre isn't one with a 4wd light.
thanks for the help
Vehicle: Daisy
Post Posted: Thu Jun 02, 2011 10:57 pm
thanks for the help
Lowrange have them as a kit, or PM weaves, he's AZ's bearing guru!
Link to LowRangeTransferRebuildKits
Oh and when I got 6.5's from Lowrange I got the gear install supplement kit and it all fitted in the $60 shipping box they use.
Post Posted: Tue Jun 07, 2011 10:33 am
I got the transfer case apart and found that all the bearings had movement. so just need to order bearings and get it back together
Users browsing this forum: Beery, Google [Bot], Google Adsense [Bot] and 802 guests
