It is currently Fri Nov 13, 2026 10:58 am
Post new topic Reply to topic  [ 155 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
Post Posted: Mon May 30, 2011 3:30 am
This was post in Monkey's build tread, I though it was betteer to make it a new tread for all of those jimny lovers who re thinking to get some kind of reduction for bigger tyres
from zukenutter - he said they were rough calculations
Mark III with Mark III gearbox + a standard 1.3 Sierra Transfer + Stock diffs = 40% reduction
Mark III with Mark III gearbox + a standard Mark II Jimny Transfer + Stock diffs = 30% reduction
Mark III with Mark II gearbox + a standard 1.3 Sierra Transfer + Stock diffs = 16% reduction
Mark III with Mark II gearbox + a standard Mark II Jimny Transfer + Stock diffs = 6% reduction
Mark II Jimny with a standard 1.3 Sierra Transfer + Stock diffs = 10% reduction
Mark II Jimny with a standard 1.3 Sierra Transfer + Mark III diffs = 16% reduction
Mark II Jimny with Mark III gearbox + a standard Mark II Jimny Transfer + Stock diffs = 30% reduction
also other options:
Trialjimny gears for Mark II Jimnys = 24% reduction
Trialjimny gears for Mark III Jimnys = 20% - 27% - 35% reduction for Manual transmission. 25% reduction for Automatic transmission
These are the 3 more common tyre sizes that Jimnys owners use and the amount of % reduction gearing needed to get it back to factory
215/75/15 = ?
235/75/15 = ?
30x9.5 = ?
Please be free to correct any mistakes and fill any gaps. Any new information post it I would update it in this first post so everyone can come back and do a quick check without going trough x amount of pages of chatting.
Also would be great if any can add info on adding 6.5 gears in sierras transfer case r 4.9 and any other option available
and thanks all for your help
:helloo:
Vehicle: On the lookout
Post Posted: Mon May 30, 2011 3:46 am
Awesome info,
Slightly off topic maybe, but regarding tyre sizes and speedometer, the 215/75/R15 on mkIII Jimny sets the speedo 100% accurate. Any larger then this and your speedo will be reading lower then actual speed. With stock tyres your speedo reads faster then actual speed.
Crispy old grand vitara
Post Posted: Mon May 30, 2011 7:32 am
It's worth adding info for the Apio replacement planetary set too. I don't have info on it to hand, but a member of the club in the Vic added the Trialjimny replacement sprockets with the Apio planetary and ended up with 5.XX in the transfer case low range.
Post Posted: Mon May 30, 2011 8:12 am
Aren't they really expensive? :(
Also there are different diff ratios to, not sure what they are thou.
Post Posted: Mon May 30, 2011 8:46 am
I've worked these out in the past but it's just from memory and roughly.
215/75/15 = 7%
235/75/15 = 11%
30x9.5 = Don't know, probably about 13%'ish
Post Posted: Mon May 30, 2011 8:50 am
Diff ratios I know of are 4.09 and 4.3, I've heard stories of autos being different in either the diffs or transfer but to my knowledge nobody has ever confirmed this for the Aussie market.
EDIT: 4.3 diffs are VVT Jimny
Post Posted: Mon May 30, 2011 9:02 am
Apio reduction on YouTube
Can't find a web listing for it For Sale though.
Post Posted: Mon May 30, 2011 10:15 am
Stock Tire - 205/70R15
Tire 1 - 215/75R15
Tire 2 - 235/75R15
Tire 3 - 30x9.50R15 >Search Tires
Stock Tire - Section Width: 8.07 in 205 mm
Tire 1 - Section Width: 8.46 in 215 mm
Tire 2 - Section Width: 9.25 in 235 mm
Tire 3 - Section Width: 9.48 in 241 mm
Stock Tire - Rim Diameter: 15 in 381 mm
Tire 1 - Rim Diameter: 15 in 381 mm
Tire 2 - Rim Diameter: 15 in 381 mm
Tire 3 - Rim Diameter: 15 in 381 mm
Stock Tire - Rim Width Range: 5.5 - 7.5 in
Tire 1 - Rim Width Range: 5.5 - 7.5 in
Tire 2 - Rim Width Range: 6 - 8.5 in
Tire 3 - Rim Width Range: 6.5 - 8.5 in
Stock Tire - Overall Diameter: 26.29 in 667.76 mm
Tire 1 - Overall Diameter: 27.69 in 703.32 mm
Tire 2 - Overall Diameter: 28.87 in 733.29 mm
Tire 3 - Overall Diameter: 29.99 in 761.74 mm
Stock Tire - Sidewall Height: 5.64 in 143.25 mm
Tire 1 - Sidewall Height: 6.34 in 161.03 mm
Tire 2 - Sidewall Height: 6.93 in 176.02 mm
Tire 3 - Sidewall Height: 7.49 in 190.24 mm
Stock Tire - Radius: 13.14 in 333.75 mm
Tire 1 - Radius: 13.84 in 351.53 mm
Tire 2 - Radius: 14.43 in 366.52 mm
Tire 3 - Radius: 14.99 in 380.74 mm
Stock Tire - Circumference: 82.59 in 2097.7 mm
Tire 1 - Circumference: 86.99 in 2209.5 mm
Tire 2 - Circumference: 90.69 in 2303.5 mm
Tire 3 - Circumference: 94.21 in 2392.9 mm
Stock Tire - Revs per Mile: 791.1
Tire 1 - Revs per Mile: 751.1
Tire 2 - Revs per Mile: 720.4
Tire 3 - Revs per Mile: 693.5
Stock Tire - Actual Speed: 60 mph 100 km/h
Tire 1 - Speedometer1: 56.9 mph 94.9 km/h
Tire 2 - Speedometer1: 54.6 mph 91.0 km/h
Tire 3 - Speedometer1: 52.5 mph 87.6 km/h
Stock Tire - Speedometer Difference: -
Tire 1 - Speedometer Difference: 5.325% too slow
Tire 2 - Speedometer Difference: 9.813% too slow
Tire 3 - Speedometer Difference: 14.07% too slow
Stock Tire - Diameter Difference: -
Tire 1 - Diameter Difference: 5.06%
Tire 2 - Diameter Difference: 8.94%
Tire 3 - Diameter Difference: 12.34%
Question- is % of reduction equal to the % the speedo is out? or is the reduction ratio something different again?
I've just ordered 5x 215/75/R15 KL-71's (can't afford the reduction gears just yet)...thanks Zukenutter for the advice RE: 235's, pretty much made my mind up.
Post Posted: Mon May 30, 2011 10:37 am
Only tyre size and diff ratio swaps will effect the speedo as it reads from the speed of rear shaft revolutions. I use GPS speed when guess-timating ratios etc, speedos are too erratic in their readings.
09JimnySierra, would you mind editing your post a bit with some spacing between sections so it's a bit easier to decipher please. Cheers.
Post Posted: Mon May 30, 2011 10:58 am
Tire 1 - 215/75R15
Tire 2 - 235/75R15
Tire 3 - 30x9.50R15
Post Posted: Mon May 30, 2011 11:44 am
From THIS thread:
"The Trial Jimny set replace the chain drive and driven gear for around 24% more reduction in high and low, the APIO set replace the planetery gears for 58% more reduction in low only.
In theory, you could fit both styes of reduction in the case for 95% more reduction (and a $3500 transfer case!)."
Post Posted: Mon May 30, 2011 11:55 am
APIO don't have an English language website, but they can be purchased through the 3rd party site Rakuten. Price is 169,000 yen for the gears, or 192,000yen "With labor" and an exchange transfer case (I guess that means fitted??)
Post Posted: Mon May 30, 2011 9:17 pm
http://www.bigjimny.com/images/document ... ratios.pdf
big jimny ratios
Post Posted: Mon May 30, 2011 9:26 pm
Keep in mind with any notes I've made so far that nothing is a totally straight swap and some fabricating and adjustment will be required. The info I've gathered has been through trial and error, also the percentages are a guide only, not exact.
Post Posted: Mon May 30, 2011 9:41 pm
Choppy wrote:
http://www.bigjimny.com/images/documents/transferboxratios.pdf
big jimny ratios
Use the UK models to compare to Aussie. I don't know about the higher diff ratio on the first G Series but otherwise this seems accurate. I used this table in my calculations.
Post Posted: Tue May 31, 2011 2:00 am
Tire 1 - 215/75R15
Tire 2 - 235/75R15
Hey 09jimnysierra, have you just assumed that stock jimny with stock tyres speedo is 100% accurate? and referenced the other sizes assuming that stock tyre is 100%? not so in my experience. GPS readings showed inaccurate speedo with the stock tyres. It's set faster then actual speed, probably to cover the manufacturer for defects in the speedo, or to compensate if someone fits larger tyres. IN my experience the 215/75/R15 rectified the speedo to 100% compared to GPS speedo. Not everyones car is the same, but I reckon your guide is misleading, I reckon 215/75/R15 is the baseline amd you should reference the other tyres and stock sized compared to that. just my opinion.
Post Posted: Tue May 31, 2011 2:05 am
i believe you can also pick up 4.8 diff gears from japan, they came out in the 660 model one, but are pretty rare and last i saw about $1000 each end
Post Posted: Tue May 31, 2011 9:53 am
Just for you Nutter ;)... if this continues i'll be lead to believe that you're just trolling the forum :D
Stock Tire - 215/75R15
Tire 1 - 235/75R15
Tire 2 - 30x9.50R15
Tire 3 - 31x10.50R15
Stock Tire - Section Width: 8.46 in 215 mm
Tire 1 - Section Width: 9.25 in 235 mm
Tire 2 - Section Width: 9.48 in 241 mm
Tire 3 - Section Width: 10.51 in 267 mm
Tire 1 - Rim Width Range: 6 - 8.5 in
Tire 2 - Rim Width Range: 6.5 - 8.5 in
Tire 3 - Rim Width Range: 7 - 9 in
Stock Tire - Overall Diameter: 27.69 in 703.32 mm
Tire 1 - Overall Diameter: 28.87 in 733.29 mm
Tire 2 - Overall Diameter: 29.99 in 761.74 mm
Tire 3 - Overall Diameter: 30.97 in 786.63 mm
Stock Tire - Sidewall Height: 6.34 in 161.03 mm
Tire 1 - Sidewall Height: 6.93 in 176.02 mm
Tire 2 - Sidewall Height: 7.49 in 190.24 mm
Tire 3 - Sidewall Height: 7.98 in 202.69 mm
Stock Tire - Radius: 13.84 in 351.53 mm
Tire 1 - Radius: 14.43 in 366.52 mm
Tire 2 - Radius: 14.99 in 380.74 mm
Tire 3 - Radius: 15.48 in 393.19 mm
Stock Tire - Circumference: 86.99 in 2209.5 mm
Tire 1 - Circumference: 90.69 in 2303.5 mm
Tire 2 - Circumference: 94.21 in 2392.9 mm
Tire 3 - Circumference: 97.29 in 2471.1 mm
Stock Tire - Revs per Mile: 751.1
Tire 1 - Revs per Mile: 720.4
Tire 2 - Revs per Mile: 693.5
Tire 3 - Revs per Mile: 671.6
Tire 1 - Speedometer1: 57.5 mph 95.9 km/h
Tire 2 - Speedometer1: 55.3 mph 92.3 km/h
Tire 3 - Speedometer1: 53.6 mph 89.4 km/h
Tire 1 - Speedometer Difference: 4.261% too slow
Tire 2 - Speedometer Difference: 8.305% too slow
Tire 3 - Speedometer Difference: 11.83% too slow
Tire 1 - Diameter Difference: 4.09%
Tire 2 - Diameter Difference: 7.67%
Tire 3 - Diameter Difference: 10.6%
Post Posted: Tue May 31, 2011 9:57 am
Just got this from trialjimny....for everyones info (recd. 31/05/2011)
Hello!
Our 20% and 27% gearsets are 750 EUR each and shipment to Australia
is 70 EUR.The 35% kit is 950 EUR and shipment to your country is
100 EUR.
All our gearsets fit your jimny transfer case without any
modification and are covered by a 2 year warranty that is valid
also in case of use in competitions.
Feel free to contact me anytime.
Cordiali saluti/Best regards
trialjimny.com
Post Posted: Tue May 31, 2011 10:21 am
What did I say?
I only asked for some spacing and for it to be edited in your original post. Now it's there three times :( :?
Post Posted: Thu Jun 23, 2011 1:46 pm
I have found some more gearing info
Here
Post Posted: Fri Jun 24, 2011 12:55 am
If yours is a manual VVT it will have a transfer box ratio of 1:1 in high and 2.002:1 in low. The auto VVT uses a different transfer box that is 1.32:1 in high and 2.643:1 in low, so could be an easy swap and still giving you a good reduction.
The manual car has 4.3:1 diffs and I think they are the same for the auto.
I think using a AUTO t-case from a VVT jimny sounds like a easy path for me now :D just trying to figure out what sort of reduction it;s going to offer...
Vehicle: 07 vvt jimny
Post Posted: Thu Sep 15, 2011 6:59 am
prolly a stupid question. But how do I tell if im mark II or III
october 2006 plated, vvt jimny.
sorry CHOP :P
Jimny's Are taking Over
Post Posted: Thu Sep 15, 2011 8:05 am
Mark III :wink:
Mark I = first jimnys, early models, non-airbags
Mark II = airbags ones
Mark III = vvt's and push button thingys
:helloo:
Post Posted: Mon Sep 19, 2011 2:09 am
Tire 1 - 215/75R15
Tire 2 - 235/75R15
I knew this was bit weird, and I had a feeling it probs was only with vvt's so I finally check it in mine
Mine is a MarkII jimny (2002 model)
I have 215/75/r15 and finally yesterday I have a GPS with me and Im 5 km/h out in my speedo...... so If Im doing 100Km/h, my speedo reads 95Km/h
so keep that in mine of that..... 205/70/r15 keep being stock tyres, not only as the 215's trow ur speedo out but also ur performance a bit too
so maybe this is a issue of Mark I and II jimnys.... and vvts is different?
Post Posted: Mon Sep 19, 2011 11:25 am
I have now got 20% trail jimny gears in...4100rpm@100KPH with slightly under size 235's. Pulls great!!! 8)
Post Posted: Mon Sep 19, 2011 8:24 pm
Now you understand what all the fuss about gears is for. So much nicer to drive.
Post Posted: Thu Oct 20, 2011 7:54 am
I need to find a mark II transfercase for my mark III jimny lol :D:D:D 30% ohh yea lol
anyone know if its a simple straight in straight out swap?? or the old different flanges and shafts and shit like the sierra case?
sorry CHOP :P
Post Posted: Thu Oct 20, 2011 8:04 pm
From memory everything bolts up perfectly but you'll need to have a custom made jack shaft. Also you'll need to find a Mark II transfer lever boot for the cab.
Post Posted: Thu Oct 20, 2011 10:01 pm
So if I put a MkII transfer into my MkIII, does the reduction only come into play when in low range, or is it always effective?
Users browsing this forum: Google [Bot], Google Adsense [Bot], winchzook and 61 guests
